You initiated the self destruct mode.
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
Looking real good mike! would autozone be able to scan ur car?1999 z28 Bright Blue Metallic 1 of 10
Dont you have a rearend you should be pulling?Originally posted by Fox Slaughter View PostYou initiated the self destruct mode.
My buddy works there and said they dont have the right one.Originally posted by Purple94Z28 View PostLooking real good mike! would autozone be able to scan ur car?
If I recall this correctly, I have a code 15 & 16. Although i dont think I have issues with either of them.
http://ls1tech.com/forums/lt1-lt4-mo...eshooting.html2002 Z28 Camaro A4
Lurker
- March 13th, 2010
- 3476
- TJ
=O I think for that attitude I will pull it and throw it in the garbage!Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Your loss, I'm helping you help meOriginally posted by Fox Slaughter View Post=O I think for that attitude I will pull it and throw it in the garbage!
How do these gauges mount in the pod? I'm about to start molding the pod to the stock pillar and I don't wanna screw myself if the gauge goes in from the back side. Or does it go in from front?
Edit: nevermind. I found out how they mount. Progress pics soonLast edited by mcalus; December 20th, 2012, 09:36 AM.2002 Z28 Camaro A4
I don't want to toot my own horn but this is going to look killer.Got the plastics prepped to be glued/bonded. I wanted to plastic weld them but it's 2 different types of plastic and I didn't want it to fail.
I should of used more vice grips but it worked out.
Used some bumper repair to take away some of the edge.
2002 Z28 Camaro A4
Dang, i may have to do that to mine!-Joel
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
Man why do the small things you do make me wish i had done the small things to mine lol. I now hate how my pod looks in my car!!
BTW i had a problem with the coolant low light being on all the time idk if you have this problem but i heard it was the sensor on the overflow bottle cause mine was always full. So i just poped the buld out. Same with the ABS light because my LED's in my aftermarket SS wing Put of no resistance in the Cruise/ABS curcuit, thus causeing it to malfunction.Last edited by white97z28; December 20th, 2012, 06:57 PM.1999 z28 Bright Blue Metallic 1 of 10
I enjoy doing things like thisOriginally posted by Purple94Z28 View PostMan why do the small things you do make me wish i had done the small things to mine lol. I now hate how my pod looks in my car!!
plus it keeps me sane for the winter. Yeah I just unplugged my coolant level sensor. I guess there is a security light bypass I need to look up on shbox.
2002 Z28 Camaro A4
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
Pfff i feel you i wish there was something that could be done to my car right now i just have no projects that don't involve lots of money lolOriginally posted by mcalus View PostI enjoy doing things like this
You have to bypass something for the coolant code?1999 z28 Bright Blue Metallic 1 of 10
- Greenville, MI
- Die Maker
It seems all over the place to me.Originally posted by mcalus View PostOkay, if I did it correct this is what I blinked to me lol
Blink, blink, quick blink
B,B,qb,qb,qb,qb,qb
B,qb,qb,qb,qb,qb,qb
B,qb,qb
B,qb,qb,qb,qb,qb,qb
Does that make sense? qb=quick blink.
it should always start with code 12 (long, short, short) when using a paperclip (Field Service Mode)
each code should flash three times and then go on to the next.
No, I have a security light on.Originally posted by Purple94Z28 View PostPfff i feel you i wish there was something that could be done to my car right now i just have no projects that don't involve lots of money lol
Halfway down the page will take care of coolant light issue
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp2002 Z28 Camaro A4
Those all did flash three times. I'll do a video of it tomorrow.Originally posted by hoogiesngrinderz View PostIt seems all over the place to me.
each code should flash three times and then go on to the next.2002 Z28 Camaro A4
- Greenville, MI
- Die Maker
Ah ok. Did you not list them in the order they were displayed? They should flash in ascending order.Originally posted by mcalus View PostThose all did flash three times. I'll do a video of it tomorrow.
You have:
21 - TPS signal high
25 - IAT signal high
16 - System voltage high
12 - No reference pulse (normal code)
Maybe you missed part of the first set, they will recycle. I'd assume 16, 21, 25 are your trouble codes, which aren't great ones to have
Originally posted by hoogiesngrinderz View PostAh ok. Did you not list them in the order they were displayed? They should flash in ascending order.
You have:
Why would I have those? What makes them bad?
Edit: my battery also went dead not too long ago and I had it on the charger. It went dead cause I have been working on interior with doors openLast edited by mcalus; December 20th, 2012, 08:00 PM.2002 Z28 Camaro A4
