    Oh no, I understand the method of going through an order of torquing the bolts to ensure that the compression is even, but they still could have given me a solid ft/lb to tighten to without having the angular degree to torque after putting it to a ft/lb... does that make sense? Not sure if I'm describing it correctly.
    Instead of:
    Torque all bolts in order down to 33ft/lb
    Repeat same order, turn an additional 145 degrees
    Do:
    Torque all bolts in order down to 100ft/lb
    That's what I mean.
    hmm, thats not the method i used then.
    I used three passes up to a final 65 pounds:
    • Well we're talking torque-to-yield bolts, so the TTY in that diagram is what I'm talking about - first pass is a 22 ft/lb, then second pass is a degree amount.
      And that diagram says TTY is 1996+ does that mean my 95 is not TTY?
      • Was Brian getting excited about his car getting closer to done?
        • 2000 Trans Am l 1967 Firebird
            I would assume so. Probably different bolts. Did you have to order bolts specifically for a 1995?
            • Originally posted by 19Xtreme99 View Post
              2015 Silverado
              • Originally posted by Xx573v3xX_Z28 View Post
                • Looking good, B!!! And don't worry about that run these guys are just jealous!!!
                  West Michigan Pontiac Club
                    Good Lord, Brian. Take it easy!
                    • Originally posted by my95z28 View Post
                      I just bought SBC generic bolts that Creight said would work on the LT1.
                        • just when I think you have purchased everything possible for that stinking car you make another post with more items!! This is gonna be nice, git r done!
                          -Derek-
                          • Ain't that the truth. And I'm holding back, too. I'd love to get a pair of 3 point subframe connectors, torque arm relocation, torque arm, PA racing k frame, tubular a-arms upper and lower, etc, etc.
                            • This car is really going to be all out!
                                Just put them on your Xmas list and Im sure Santa will be very good to you.
