Boost or Spray
  • #91
    Originally posted by Gaspo View Post
    my sts turbo with long tube headers was fully spooled at 2800rpms. it was real loud, but yes, very visible from the rear. not much of a sleeper unless you look under the hood. but then you see the blow off valve.
    What turbo and how much pressure?
    Used to own a Firebird.
    • #92
      A rear mount will spool fast if its set up right. If you went back to manifolds I'm sure you would have gotten it to spool 500 rpm's before that even. You could always use a quick spool valve too. Zombie on tech has an ST80 with a valve and from his street vids that thing spools wicked fast.
      • #93
        boost is the way i would say to go, listening to turbo spool up and you can use it at almost all rpm ranges and what not...brake boosting is fun, got a buddy that boosted his camaro..
        • #94
          http://detroit.craigslist.org/wyn/pts/2162773238.html
          Procharger on CL
          • #95
            Those who spray, on a regular basis, how many times did you refill your bottle last year?
            Can a 15lb fit in the spare tire area?
            • #96
              Anyone know the difference between the lt and ls procharger kit?
              • #97
                ah I didnt read to see that it was for a LT1... I dont know the differences.
                • #98
                  Should be brackets.
                  • #99
                    did a rear mount on my buddies camaro now we are suppose to be tt'in it up lol
                    • Originally posted by sman View Post
                      the speaker has to be removed if you use a 860 mount
                        What I've heard is that the LS1's use a reverse rotation head unit and the LT1's don't.
                        • it was a 67 and 5lbs of boost
                          • Any thoughts to like a magnacharger setup? i know a couple peeps with a ls1 GTO's should be about the same. Though i think you would get the most efficient gains with a procharger setup...
                            • Originally posted by Dummybait View Post
                              won't fit under the cowl without spacing the k-member down and the kits that are complete don't come cheap.
                                yeah i heard that somewhere.. forgot about that...
