Smans 5.3 build up!
  • Larry is correct it connects to the block just above the starter.
    • That spot where it connects just above the starter, its not there on a 5.3. Its just flat. I did move it however more twards the front of the motor, in the A/C compressor area, there was an unused hole in the block from the truck A/C system.
      But I did get more done than that..... teaser pic....
      • -Joel
        • Congrats Spence! Engine looks great back in the bay!
          • Looks great!
            • so... are you going to get a different air lid so that it lines up with the TB or is the tube just gonna have to make a little jog?
              • Getting a different lid, this is to far out of alignment, plus I have to get the MAF in there somewhere.
                • sorry i got rid of the lid haha that ones def not gonna work!
                  2002 Camaro SS # 3047
                  - Cam, Boltons, Tune
                  • Looking great, congrats on the progress! When are you expecting/hoping to have it done?
                    www.BroughtonAutomotive.com
                    www.fquick.com/Camaro_Driver_19
                    • Sorry no pics but im at work. Got a TON done today, motor is completely in, was just sitting on a jack in the picture, tranny is mounted and has 5 quarts in it, shift cable bolted up, drive shaft in, all the wiring done, interior passenger pannel on, shock towers bolted up, and then I had to go to work.
                      As soon as I get home Ill be mounting the tranny cooler to the condenser, installing the tranny cooler/condenser/radiator/fans assembly, hook up the upper and lower hoses, put the battery in, followed by the lower air box, then Ill come back in the morning to start it.
                      • Man you don't play around, hope you post a vid of the startup on the first 4th gen 327ci that i know of!
                        Originally Posted by 1BADAIR
                        • We will have 2 video cameras, a still digital, and iphone, and a blackberry. We'll have plenty of media
                          • Congrats Spencer! You definitely beat me to the first startup - better post the media with all those resources at your disposal!
                            • Originally posted by sman View Post
                              When you firing it?
                                When you firing it?
