Yeah, I need the 4l60e for an ls engine, you are correct. I normally make a hand gesture and walk away also but between work hours and parts availability I wouldnt be getting anywhere. If I am not mistaken I also need the trans from a fbody due to the torque arm mount. I also need the accesories from a ls f body unless there is another cost effective way to do this. As far as a race to the finish.....thats not happening. Lol. I just want to get it running enough to move around under its own power. For now....
A 4L80e will fit? I still need a tail shaft housing from f body then for the torque arm mount. So I need to find a housing then. Edit: you are talking 4L60E Trans from a light duty truck.
yup 4l60e from a truck or suv, tahoe, silverado, just need to make sure its a 2wd for easy swap.
I have a line on a couple used ones. I am willing to take a chance on one for the money. Another question about the truck trans. What do I do with the shifter shaft? What is the modification?
t
Ahh, Yea it sounds like I am in the lead at the moment but I am sure you will catch up quick.
