Originally posted by DynoDave
View Post
Replacement build thread. 1999 firebird.
Lines and radiator already cleaned out with brake clean and compressed air. Not taking any chances... So I rebuilt the power antenna in the Firebird today, I also did the one in the Camaro....and a spare. Got a little carried away ....
Installed the honey comb tail lights in the fire bird. ran out of motivation after that.
So now I think I am going to fix up the harness a bit while I , once again, have acess to it. I have the correct no adhesive tape . I would like to finish the looming and there are a couple wires that need to get corrected. So another slight delay but itll be beter in the long rub me thinks.
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Looks nice! Stock or built? Also, where did you get the non-adhesive tape? Would love to get my hands on a couple of rolls of that. Sent from my Pixel XL using Tapatalk
Trans is back in and appears to be functioning correctly now. I couldnt manually select first gear @ first. So went to see gols1go, Ken , fixed her up for me. we reloaded a stock 2002 ss. trans tune to the pcm, so I can have a stable starting point. All is well now.
The trans is completely rebuilt by Richard @ Detroit Gear Box. Lots of goodies inside. He also cleaned out my converter for me since it was full of material from the burnt 3rd gear in the trans before the rebuild.
For the harness, I fixed the wiring on the o2's , and re wrapped the harness with the adhesive free tape I bought and finished the looming. I elected not to get into correcting the 2 injectors that needed to be swapped around , it was just to far into it, and I didnt want start cutting wires and soldering.
I failed to get any pics of the work going in, Its been way to cold for that , and I just wanted to get this stuff done.
I purchased the masts from ebay for about $16.00 they also sell gm part but they were very expensive.Originally posted by Lucky SOB View PostWhat parts did you use to rebuild your firebird power antenna? I'm trying to track down the right part number for the antenna and ribbed white plastic cable part. Sent from my iPhone using Tapatalk
Picked up my hood last week, its on the car. looks good! Still haven't been able to figure out whats up with the fuel gauge, making me a little nutz. Its slowly coming together. I have been debating removing the newly rebuilt 4l60e and installing that in the Camaro and getting the 4l80 e I will need fore the turbo build and just going that route without driving the car naturally aspirated. I am not getting a lot of time to work on it right now so I would like to make the time I do have count. dunno....
