Aint nothin some 140 runs wont clear up.
Oil/fluid smell in interior
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
I had rear head gasket leaking, there was oil sludge built up on back of block and bell housing. This was not sweet smelling. When I replaced head gaskets it was bad from water jecket to edge of head/ block so no oil mixing or signs before hand just using a bit of antifreeze.
When you get car on rack feel up top around bell housing see if its wet/oily.sigpic
Sounds like thats the head gasket issue i have, and if thats the case im just leaving it until it becomes a problem. It doesnt look like a gushing leak and isnt dripping.
I can guarantee the bellhousing and back of block is oily without even looking at it, it just always has been. I didnt know about the dimple trick for the "china wall" when i did the top end so it leaked almost from day one.-Joel
Could be. The smell doesnt exist anywhere, in or outside of the car when it is parked and not running. Even if it had been running and hot minutes prior.-Joel
Still going on, except now I'm starting to think its coming from under the center console. I'm going to try to investigate this weekend.
Edit: lightbulb just went off - My dad also changed my trans fluid this winter. ATF would be a similar a smell, thinking maybe my transmission is over-filled.Last edited by JoeliusZ28; May 2nd, 2013, 01:13 PM.-Joel
Very good possibility, although if it was REALLY full, wouldn't it oveflow at the vent cap and make it on to the ground?Originally posted by JoeliusZ28 View PostStill going on, except now I'm starting to think its coming from under the center console. I'm going to try to investigate this weekend.
2001 Bright Rally Red Camaro SS - M6, Livernois Stage 3 ported 243 heads, Livernois 230/236 114 LSA cam, FRPP 36# injectors, Ported TB, SLP MAF, Volant CAI, Kooks 1 3/4 headers & ORY, GMMG Cat-back. Koni SA 4/3's, BMR springs, Founders Performance, STB, LCA's and Panhard bar.
You would think, but the car hasnt dripped any fluid on the ground that ive noticed all spring.-Joel
Well i prefer niether. The rich idle is bad enough
Originally posted by JoeliusZ28 View PostWell i prefer NEITHER. The rich idle is bad enough
Fumes already getting to you....fixed it for you guy
Can anyone tell me where the vent tube on a t56 is? Just looked at it on the hoist and dont see anything. I am desperate to figure this out, i am nautious/high/headache after the drive back from the m&g. Had to have the windows all the way down.-Joel
jk... But the smell seems to blow directly out of the vents if thats what you are asking.
