I dont think longer push rods will effect cranking compression at all, if you have them adjusted properly. It will just mess up your valve train geometry pretty bad. Eric L
Vinnie's dyno results
I believe that my pushrods are 25 thousandths too long but I'm not sure. Other than that I can't adjust it because I've still got the stock rockers-torque to 22 ft. lbs. and that's it. I can't think of anything else that might cause this other than something in the tune.
Used to own a Firebird.
Just because the duty cycle was that high, dosent mean your running out of fuel, it just means that the injector is REALLY working. If your A/F ratio on the wide band didnt lean out at high rpms than your ok. I think your dyno numbers sound fine for the mods done. What is your new compression ratio with the LS6 heads and gaskets your using? From friends of mine that have done similar mods, I think your numbers sound fine. Do you have a graph to post?
His number are low if you ask me, we had a cam only car dyno at the dyno day that had untouched heads and a slightly bigger cam and that put down 415rwhp. It did have a FAST intake but thats still minimal difference. Track numbers will tell all though. Hows your clutch?Doing less with more
What are factory chambers vs LS6? Is there a differance in chamber size at all? And what gaskets is he using. Are they thicker or thinner than stock? Issues like this interest me. Eric L
CraigSemi Retired Street Racer2012 Lava Red Mustang GT 5.0 MT82GONE BUT NOT FORGOTEN
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
- Smokey Yunick
