Actually there is NO coating on the rears, just as cast iron. Mine had never seen winter and was all surface rusted, same with the front spindles.
some of my winter projects
well i got the splashgaurds back in and the passenger side brake setup and wheel back on.
However, i just finished the driver side and it appears i have a leak where the line meets the caliper. I messed with it for a half hour and same result every time. Its not a small leak either and yet i cant tell exactly where it is coming from. I was so close to being done, the light at the end of the tunnel so bright, could already smell the exhaust fumes and burning rubber,... and now this
ugh, ill deal with it tomorrow.Last edited by JoeliusZ28; April 30th, 2008, 11:05 PM.-Joel
it actually has 90xxx on it right now.Originally posted by badinfluence View PostI would have thought your car had alot less than 75+K miles
hopefully you didnt break a metal line, good luck!
i didnt break a metal line, its leaking out of the crack where the line-end bolts to the caliper... and i dont know why. as soon as i take the vice grips off the line: drip-drip-drip!!! It doesnt look any different than any of the other connections which arent leaking.-Joel
I always thought your car was clean, but i thought it had less miles. Very cool its still lookin like that, very cleanOriginally posted by JoeliusZ28 View Postit actually has 90xxx on it right now.
thats wierd its leaking...looks like you'll be re-doing that tomorrow
'96 Camaro RS - project
'97 Silverado Z71 - DD
'89 Suzuki GSXF 750
thanks
thing is i dont know what to do about it, i tried everything i could think of... like cleaning the contact surfaces. the copper washer looks fine too
im hoping my dad will have some ideas.
You might want to try some teflon tape or something if its leaking around some theads. And make sure the brake fluid isnt leaking on the caliper all night because it will DESTROY the praint you just put in there.
teflon tape is a good idea, ill probably try that.-Joel
could be a small crack in the line? maybe when you have the vice grips on you are closing that gap?
hmmm...i checked for that, but that still could be. I REALLY hope notOriginally posted by k0261886 View Postcould be a small crack in the line? maybe when you have the vice grips on you are closing that gap?
ill hit it with some brake-kleen and find out for sure.-Joel
ok i figured out what the problem is. I wasnt working in the brightest of light yesterday and hadnt noticed the rest of the calipers actually had two copper gaskets on them, one had just always stuck to the calipers upon removal. Well apparently this one didnt stick as good, and fell out somewhere along the line... im hoping my dad has one laying around, otherwise i get to run up to the auto parts again. at least its simple
Joel, I REALLY like that red color you are using for the accents on your car. . . I might have to borrow that idea when I paint my calipers and suspension pieces. . . I'll probably go with black or grey instead, though. . .
Looks like you're moving right along, can't wait to see it at the M&G!
Nick H.
Current MIFC Vice President
thanks nick!Originally posted by 93formulalt1 View PostJoel, I REALLY like that red color you are using for the accents on your car. . . I might have to borrow that idea when I paint my calipers and suspension pieces. . . I'll probably go with black or grey instead, though. . .
hoping to have it done tonight, and i might attempt getting the wheels done for the M&G too.-Joel
