some of my winter projects
  • #61
    why is that? its better to have a wideband reading on a gauge than the narrowband which doesnt tell you much of anything.
    Idk maybe i should just get rid of the gauge altogether and put something else there.
    Well, if you have the WBO2 installed and ready to rock why not install a WB gauge? What WBO2 did you buy?
    • #62
      Innovate LC-1
      • #63
        worked on the car some more last night
        Test fitting OEM SS Spoiler (from SSRhodes car):
        anyone know what would cause this?
        Painting rear axles, I think i might sell one.
        Progress under the car. Almost done with the front end and mid section. Removed a bunch of worthless exhaust heat shields too.
        • #64
          You have a ton of work before you can get her back on the road.
          1997 Trans Am
          www.fquick.com/transampimp
          • #65
            damn joel looks great
            • #66
              I know. Im seriously working on it like a bat out of hell everytime i come home for a few hours.
              • #67
                if the car even dirty?..doesnt even look like it
                • #68
                  Looks like you got some LED's burned out or cracks in the circuit board causing them to not light up.
                  Wade
                  • #69
                    what would you suggest i do? Should i just replace the whole piece?
                    • #70
                      Not sure how easy it is to solder in new LED's in that circuit board. It would be easiest to replace it, but probably expensive. I'm not sure if they're even still available from GM.
                      Wade
                      • #71
                        well I worked on the car all day today. Pretty much got the painting done, and boy does that make me happy!!!
                        here's my new wires and alt i never took a pic of:
                        • #72
                          not done with the sway bar yet, but you get the idea.
                          now i get to start putting everything back together!
                          ...after i touch up that one spot i missed on the gas tank...
                          Ive also decided im leaving the SFCs black for now.
                          • #73
                            I dont think I have ever seen really nice pictures of your car before, that red is AMAZING! The STB and sway bar, is that powedercoated a candy or what?
                            • #74
                              thats anodized red, you can buy it murrays in a spray can. Its called metallicast i believe... a little more expensive but yea its basically a candy paint. its translucent so whatever you apply it over shows through. I painted the sway bar a metallic silver as a base coat.
                              • #75
                                Looking awesome, Joel!
