Yeah...need to email Rock Auto to see how they can make this right. I'd prefer not to get a refund (as they're out of stock) and then have to go spend $10-15 more somewhere else.
Got my 2.5mm nutdriver today, plugged in my OTC Monitor 2000 and checked TPS voltage with the ignition on, but the car off, since that's basically equal to curb idle (assuming it is set correctly - hard to tell when you have an idle that seemingly changes based on the day). Turned the adjustment screw all the way in (which should lower the voltage - I believe it pushes the TPS down the barrel, allowing for the plunger to "start" further out) and basically saw no change.
I also found that my new tool is the perfect size to remove the roll-pin out of the accelerator pump arm - something I was not able to do previously! With the pump arm detached from the air horn, the TPS plunger (and the pin above it that contacts the arm) were free to be "out" all the way, which means voltage should be as low as possible. Didn't make any difference. I did confirm - with help from my new favorite tool which has found another perfect application - that the TPS plunger itself, as well as the metal pin above it both move freely.
In my mind, it looks like I just need a new TPS. Now that I've gotten the accel pump off the top, I should be able to remove the air horn much easier and with the carb on the car.
. Once I got that dialed back in (even though nothing moved), I took it out for the first drive in a year...felt great! Car seemed happy, chirping second with ease, "accidentally" lighting the tires up turning left from a stop back into the sub (don't worry, I let off the throttle and did not take out the stop sign like that Charger Scat Pack did a couple months back)...might be out a second time this week on Friday...
