Yeah, I have thought about trying to do that was well. Hole might be big enough where I can just shove the bristles in from behind and get it that way.
1981 Camaro Z28
Changed all the plugs today (had pulled plug 6 previously to replace the dipstick tube and it looked pretty bad), and got the new starter installed.
The new starter was far more pleasant to hold above my face as I installed it (had to do a little bit of filing to the opening in the block plate).
Considering I removed the original starter last August, it's nice to have a new one installed, finally (assuming it doesn't have issues - I can't test yet, as I need the battery out to do the body bushings).
Top row of plugs is driver side, bottom is passenger, running rear to front, left to right. I put these in back in 2016, and they only have a few hundred miles, but a lot of idling on them. Varying levels of how the plugs look - but plug six is clearly garbage.
345641960_254180540401119_3403885194309325439_n.jpg?_nc_cat=108&ccb=1-7&_nc_sid=0debeb&_nc_ohc=7h0Jx_AtCL8AX8Fb0nA&_nc_ht=scontent-ord5-1.xx&oh=00_AfA0LX-Y5A0x4_xzauv4t05nfOP1iY0UC_Qth9T58kbskQ&oe=645D1B20.jpg
345236266_243019548311251_6506971628915961081_n.jpg?_nc_cat=102&ccb=1-7&_nc_sid=0debeb&_nc_ohc=IUD5ehcN4qgAX811brE&_nc_ht=scontent.fdet1-2.fna&oh=00_AfBiYfOn4WI43OJC2iVmpvZ9XMHwDAXRDlDa5X7sAQvXoQ&oe=645CCCAD.jpg
344771422_6406936569369963_2674961996353437981_n.jpg?_nc_cat=103&ccb=1-7&_nc_sid=0debeb&_nc_ohc=3bTHyPxK4-cAX8wpb04&_nc_ht=scontent.fdet1-1.fna&oh=00_AfDp59EuIa_NAUNVeNi6VkWKsQhoPgpMWIEPW4ywsJQF2g&oe=645DE664.jpg
Original 10MT starter vs the new PMGR starter. Wayyyy smaller. And wayyyy lighter.
345429124_1632333737242756_3514597867583575845_n.jpg?_nc_cat=104&ccb=1-7&_nc_sid=0debeb&_nc_ohc=rvhKfOC5UnwAX_vhfDM&_nc_ht=scontent-ord5-2.xx&oh=00_AfBA2HxjksqxRb2-C1Ot_Yy_DpmguOqpIHx0nd5Irx-imQ&oe=645CF7A1.jpg
345648036_1214190932594172_946793914601529107_n.jpg?_nc_cat=102&ccb=1-7&_nc_sid=0debeb&_nc_ohc=xJFWdmsyb8oAX8XgI4N&_nc_ht=scontent.fdet1-2.fna&oh=00_AfD-rhaaAG6iZ4Oc_JSUxKggIn4FZfn6a_SNaPOFlMI-KA&oe=645C933F.jpg
Installed (don't mind the nastiness under here...)
344924138_919093342639033_4239929617604647161_n.jpg?_nc_cat=101&ccb=1-7&_nc_sid=0debeb&_nc_ohc=wRram1oK85QAX-KyObI&_nc_ht=scontent.fdet1-1.fna&oh=00_AfBIjU87foaJvEeOuNXIEJ2XTJLCVK3TTI9Cpy0yPL_c8g&oe=645CD723.jpgLast edited by MP81; June 9th, 2023, 10:05 AM.Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
That's what I'm going to guess - either that or it's not firing at all. That plug wire is basically impossible to know if it is seated or not, so it's entirely possibly it was simply not attached, not firing, getting coated in small amounts of oil (I'm sure the seals are past their prime, but it doesn't really smoke) until it looked like...that.Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
Got a lot done today, and I certainly am feeling it.
Started off adding some heat-wrap to the starter wires, just to add an extra layer of insurance near the headers with how they route to this starter versus the stock one. Then I tackled the body bushings - they were clearly, absolutely, shot - so the new Global West aluminum ones should be a massive improvement. I made sure to put the alignment pins in when I was doing all this, just to be sure the subframe was actually in the right spot. All went pretty well there - right up until the end when the last one's cage nut broke free when I was going for the second click of the torque wrench. Go figure.
Since the front right bushing was all installed and torqued, I put the new battery tray in the newly POR-15'd area, which looks so, so much better.
Starter wires wrapped:
346871770_614858900597525_5739101472973243786_n.jpg?_nc_cat=103&ccb=1-7&_nc_sid=0debeb&_nc_ohc=fSKsAafQqB0AX8ciXhZ&_nc_oc=AQl2bxOlbF6FBwAVU6r_5rMNZkj5FHscUS0bAbJLCHmfQUiMNqkLmS-Tq0OOZp3wNq8&_nc_ht=scontent.fdet1-1.fna&oh=00_AfAjFVG
Right side firewall bushing versus the new ones:
346474688_5916856875107880_8812505292295726197_n.jpg?_nc_cat=104&ccb=1-7&_nc_sid=0debeb&_nc_ohc=v7R7F7-qKTEAX-Vki-q&_nc_ht=scontent.fdet1-2.fna&oh=00_AfCq8CSXBRTT3XYBFudDwJt-MX6ilSMbaUPOtaN7YbNduQ&oe=6466153D.jpg
346943423_579470760682885_5284266145937726127_n.jpg?_nc_cat=110&ccb=1-7&_nc_sid=0debeb&_nc_ohc=Fjj3BlLPKAQAX9Nv1cg&_nc_ht=scontent.fdet1-1.fna&oh=00_AfB3Ty3VFlA2ZN3f73AWEOM29HGap-rzelmt0TysQSrxTg&oe=64649E1F.jpg
Right side rear bushing compared to the new one:
346602683_1007455896912194_1745097741771301111_n.jpg?_nc_cat=108&ccb=1-7&_nc_sid=0debeb&_nc_ohc=2ILXEvuyEVcAX_25YCB&_nc_ht=scontent.fdet1-1.fna&oh=00_AfArL7vHcjUO8CHh6RiiVSCQxj6DAWd3H3cmht29vyHNFA&oe=6465819B.jpg
Right side radiator bushing vs the new one - notice the lack of nut. It looks to never have been installed:
347086057_1392469761546597_4406555574012473418_n.jpg?_nc_cat=110&ccb=1-7&_nc_sid=0debeb&_nc_ohc=RsXngbCtY7gAX8hb_gQ&_nc_ht=scontent.fdet1-1.fna&oh=00_AfBF7qdRbHGNgLOcoBP5cRLWwGsVEIASu-X-4s-JiX0Rdw&oe=6465B722.jpg
Left side rear bushing:
346600468_1430693404349768_6692307362438642503_n.jpg?_nc_cat=109&ccb=1-7&_nc_sid=0debeb&_nc_ohc=bQoN37K2LPYAX8Uvjg2&_nc_ht=scontent.fdet1-1.fna&oh=00_AfBXpczYMR3Y52G45vKyhGJ4fM69VSJn275RX89cvNW5WQ&oe=64654929.jpg
Left side firewall bushing:
346837102_3442749842679284_3312320763257313449_n.jpg?_nc_cat=109&ccb=1-7&_nc_sid=0debeb&_nc_ohc=mUmJR2WhTiwAX8XCM3H&_nc_ht=scontent.fdet1-1.fna&oh=00_AfCCgph8pMbqVjL_fytCYxglvig5Mhv65Os-Tfryil6YLQ&oe=6464896C.jpg
Left side radiator bushing - this one did have a nut:
346495282_6307341979322474_3221641189360260689_n.jpg?_nc_cat=107&ccb=1-7&_nc_sid=0debeb&_nc_ohc=XyOHH6hKUa8AX8guQp-&_nc_ht=scontent.fdet1-1.fna&oh=00_AfB_1rUTtBUcYvSxxU0vdOegJdko1sQelMAj2Ou4hcw7og&oe=6465690D.jpg
New bushings installed (along with my 3/16" steel inserts for the rear ones, to take up the thickness that the SFCs eventually will when I have them welded in):
346786981_539198168200899_2980943579907146713_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=0debeb&_nc_ohc=MGsfjKI9jQEAX_r3elb&_nc_ht=scontent.fdet1-1.fna&oh=00_AfDYq4kCd_U-3k_b4GTH8eQj74ty5VrdD7oNKbii-zlDmQ&oe=64662215.jpg
346966186_1301811227413976_7005818843469972496_n.jpg?_nc_cat=109&ccb=1-7&_nc_sid=0debeb&_nc_ohc=hiRqrEVy5l8AX8goEXc&_nc_ht=scontent.fdet1-1.fna&oh=00_AfAb09QySOHrSTmhUTJa-Xz417kdWHztYF6LwlUde1v09g&oe=6464C473.jpg
346612090_185485311110332_1673895439889500016_n.jpg?_nc_cat=111&ccb=1-7&_nc_sid=0debeb&_nc_ohc=YuPaeZ8JNYUAX_xbVHC&_nc_ht=scontent-ord5-1.xx&oh=00_AfC6pz1MYY1OiAzySHtEaPteuIfYT61j2-QUN5BdyJMKcA&oe=64646F5A.jpg
346815192_547354217585886_5802029994614445020_n.jpg?_nc_cat=108&ccb=1-7&_nc_sid=0debeb&_nc_ohc=ZgLdL5_XsGsAX90xXhK&_nc_ht=scontent.fdet1-1.fna&oh=00_AfChw9mzh5xKG7VlomTDjunxEarXczxBzqh2vnp_9cBYsQ&oe=6464951F.jpg
346642301_630573612268391_3002297363777013084_n.jpg?_nc_cat=106&ccb=1-7&_nc_sid=0debeb&_nc_ohc=BF89qR2rTNUAX83d5gx&_nc_ht=scontent.fdet1-1.fna&oh=00_AfA2t-d5dPq5taVCepKH6Pky8tUHfkhyP-iRh2h74max2g&oe=646485A5.jpg
346661468_760297402446713_2813500624225845794_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=0debeb&_nc_ohc=oO7vOov0GbAAX_Rj3G6&_nc_ht=scontent.fdet1-1.fna&oh=00_AfAQC6NN7ehfNqhOAcLLwiPMgDgzMj8L3idES2SD0U_CsA&oe=64650E43.jpg
346778162_635240121368861_6084622621455453838_n.jpg?_nc_cat=110&ccb=1-7&_nc_sid=0debeb&_nc_ohc=WbxbsZc44rMAX_neVZC&_nc_ht=scontent.fdet1-1.fna&oh=00_AfBzB3wD7QL7jCHXXfdXFiKmldyxJwXoBKzT4_xGCZaCbQ&oe=64655020.jpg New versus old battery tray:
346487504_6686236461396213_4450094920704533997_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=0debeb&_nc_ohc=S7LA07cra1IAX9FflKx&_nc_oc=AQktgkv70oF8XDueK4AAemB3xZNMS4xK99nOi_97k1ChQvRH1FbWLhKFXD1ApNpTCm4&_nc_ht=scontent.fdet1-1.fna&oh=00_AfC0Pr
New battery tray installed:
346476143_570311078572969_4534077503033265830_n.jpg?stp=dst-jpg_r270&_nc_cat=104&ccb=1-7&_nc_sid=0debeb&_nc_ohc=WReE6Y9fqS0AX8D8hUf&_nc_ht=scontent.fdet1-2.fna&oh=00_AfCsYhucxE5WzK4CADsWZCbJGkJ6f96fynIzR2WzAQxczg&oe=6466215D.jp
Over the course of definitely too long of a time, got the trunk POR-15'd, smoothed out with Bondo Glass to make sure the seal wasn't ruined by a shitty surface, sanded down, primed and painted (just used black - may go back and color match it at a later day...or not) and back on the car. Seal should be much happier now!
POR-15 down:
352788797_10159685200698597_108312841550760571_n.jpg?_nc_cat=102&ccb=1-7&_nc_sid=0debeb&_nc_ohc=7qd9fg9UiAgAX_71yrQ&_nc_ht=scontent.fdet2-1.fna&oh=00_AfA0k7sGJh_Xa9C99Ni2lle6nfztwFRf5vQwudrU1Vus4Q&oe=6488496E.jpg
352810594_10159685200568597_3458468556800444375_n.jpg?stp=dst-jpg_r270&_nc_cat=108&ccb=1-7&_nc_sid=0debeb&_nc_ohc=TLXc9PIYlecAX9w4lOF&_nc_ht=scontent.fdet2-1.fna&oh=00_AfA8fUnG9KD9fRk7-K2nS74172VYl8h050UJAezRLbIIpQ&oe=648773FC.
352821879_10159685200518597_1043549093692214044_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=0debeb&_nc_ohc=C4t4G0hFNfsAX9_GMrX&_nc_ht=scontent.fdet2-1.fna&oh=00_AfAFNvw1eeWWbvRo7dam_zsPI6xNc5EUKvYH94VCADlTtQ&oe=64888FE6.jpg
352939727_10159685200623597_2888870869346725694_n.jpg?_nc_cat=108&ccb=1-7&_nc_sid=0debeb&_nc_ohc=h5uY3aeTp1cAX_8caeR&_nc_ht=scontent.fdet2-1.fna&oh=00_AfBMy6jeNZgiAXvMQLXG-9kpzKewBqh-W7ip_pTuM1FtMA&oe=64879F2C.jpg
Bondo Glass applied and sanded down:
352794696_10159685200938597_1923369648831811860_n.jpg?_nc_cat=101&ccb=1-7&_nc_sid=0debeb&_nc_ohc=mnJ4zDuHKiYAX_CRMFM&_nc_ht=scontent.fdet2-1.fna&oh=00_AfAhbmaSHqawuVECCYUtL00MCnZfLAY7fjlS5EX-yQ86Gw&oe=648911D2.jpg
352976764_10159685200923597_8733361158579638293_n.jpg?_nc_cat=108&ccb=1-7&_nc_sid=0debeb&_nc_ohc=6V6LbaZAqowAX8IsXWq&_nc_ht=scontent.fdet2-1.fna&oh=00_AfAS6J0hjW21ZCtZuSEh_yNGZmyWXPtdA_hNxUfou-F5mA&oe=6487DA43.jpgimage_61650.jpg
Taped up:
352775760_10159685201203597_4508264219042530396_n.jpg?_nc_cat=109&ccb=1-7&_nc_sid=0debeb&_nc_ohc=aRgPadIAkVIAX-Zj2z0&_nc_ht=scontent.fdet2-1.fna&oh=00_AfAJdUrn_PfW7Ct6P6R8lJ_sirydak6Pgaor3oHt6DDbCQ&oe=6488E871.jpg
Primed (the first three coats I did...I got to do three more after the Duplicolor Prep Spray just...took most of the primer right off...):
352971233_10159685201198597_7688532778294244552_n.jpg?_nc_cat=103&ccb=1-7&_nc_sid=0debeb&_nc_ohc=GL-DGFulT0IAX90cmvX&_nc_ht=scontent.fdet2-1.fna&oh=00_AfATHtUffjqff58wRD_eUBC8obO_uLxJj0ZgloA1Z10toA&oe=64884A2F.jpg
Painted:
352816203_10159685201258597_3730154887597865098_n.jpg?_nc_cat=104&ccb=1-7&_nc_sid=0debeb&_nc_ohc=x-Wj1T1wpVAAX_aYnJX&_nc_ht=scontent.fdet2-1.fna&oh=00_AfDTsBDTmaFkQ-4ijh-MPS1hTX6sCPt1WZKgJmSMD_9taw&oe=6487AC9D.jpg
Untaped - bit of a hard tape line, but it's fine, the seal won't have an issue with it:
352964766_10159685200598597_970690202658351990_n.jpg?_nc_cat=104&ccb=1-7&_nc_sid=0debeb&_nc_ohc=ZudaXY-3QIoAX-Fs8n9&_nc_ht=scontent.fdet2-1.fna&oh=00_AfDez2YAfO-YiGZDktqCn2R-0kPAdPga6cy6AJx4zmJdVA&oe=64878C20.jpg
Reinstalled on the vehicle after only like...a month:
352649376_10159685210228597_3121130365397785940_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=0debeb&_nc_ohc=QqQDN-8-SE4AX9q1pFY&_nc_ht=scontent.fdet2-1.fna&oh=00_AfAgAS-pPUATCPJykIJVvVt2qwmeCD3chlhWCRxDT0F43Q&oe=64890C90.jpg
352810695_10159685200338597_2841888237857950410_n.jpg?_nc_cat=109&ccb=1-7&_nc_sid=0debeb&_nc_ohc=Mg1hXwTxdKEAX_kbiJH&_nc_ht=scontent.fdet2-1.fna&oh=00_AfBwZXouCRcxDyY5Cap4VLzeIzuRSGF-DVzn5zjn_xBb_Q&oe=64882397.jpg
Decided to try out some Patina Sauce on the car after seeing it on Hot Rod Garage (with the Savoy drag car)
As it looked before - dusty from sitting for a year and half and all:
352969567_10159685218863597_6814140208013620834_n.jpg?_nc_cat=103&ccb=1-7&_nc_sid=0debeb&_nc_ohc=Qf-_fhL9XxIAX9lYqIH&_nc_ht=scontent.fdet2-1.fna&oh=00_AfDv-Rs23SntT9PqKv3edihMjAJoTBDB1KdCVkVfQRIg4Q&oe=64880D7C.jpg
After their cleaner, and then two coats of the sauce - quite impressive!
352972818_10159685218798597_7296953757497078468_n.jpg?_nc_cat=110&ccb=1-7&_nc_sid=0debeb&_nc_ohc=BL0B6tnR9YYAX8XNdmj&_nc_ht=scontent.fdet2-1.fna&oh=00_AfBOgckZjC4Ck6KbmiG4coJB9u3LlxJMmKLIid9th5IvgA&oe=64891E2A.jpg
352468914_10159685218848597_8643586112024190287_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=0debeb&_nc_ohc=zx5b9TXAhQgAX8Hp9mZ&_nc_ht=scontent.fdet2-1.fna&oh=00_AfB1GRKqm5RDBljvQtVnGGt-SH9FZLIxfRnaDyKp7FjVVQ&oe=6488565E.jpg
Might do one more coat on the horizontal surfaces of the car, but otherwise, it should be all ready for the show tomorrow! I started it up and let it run for ten minutes yesterday as well. Took a lot of cranking to get fuel to the pump, but the new starter was far less of a draw than the old one, and spun way faster.Last edited by MP81; June 9th, 2023, 02:52 PM.Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
Absolutely - talk about a massive relief that I got the car all done (at least what I wanted to) by the show!
It drove well - it still has the weird inconsistencies in terms of running, but as far as driving, the hard left hand turns did not seem to result in rubbing, so I think that the bushings definitely helped there! I need to get it back to Brian for a re-alignment now that I've effectively changed the suspension geometry - perhaps we can dial in the camber numbers without resorting to 6.5 degrees of caster (which tilts the wheel back further and definitely doesn't help matters - though it's positive for handling).Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
Finally got around to installing my fancy headlights in the car today - Dapper Lighting LED Sevens. What a difference - both in terms of looks, but also light output. I still need to aim them, but the aim is pretty close right now since I didn't change any of the aim of the bucket at all.
Halogens (mismatched):
384304297_10159917497103597_306201398661217531_n.jpg?_nc_cat=103&ccb=1-7&_nc_sid=813123&_nc_ohc=D8l4kZebtvcAX-gLD_f&_nc_ht=scontent.fdet1-1.fna&oh=00_AfDIh-wY7bANSSEVXTCuRD-LHzKUzuu8oOYm1ljO5Nj4RQ&oe=651D55DE.jpg
Stock low beam light pattern (only about 4-5 feet or so to the Volt, so pretty close):
384656259_10159917496648597_3883927095934397629_n.jpg?_nc_cat=105&ccb=1-7&_nc_sid=813123&_nc_ohc=OVg1Qo5KEDIAX81xS6R&_nc_ht=scontent.fdet1-2.fna&oh=00_AfD8RqRKl236AK-Ndofh3K10zbBQCKtR559cBGFlNWmu2w&oe=651CA11B.jpg
Stock low beams:
383969408_10159917497418597_1452678285930599602_n.jpg?_nc_cat=108&ccb=1-7&_nc_sid=813123&_nc_ohc=PqboA68h4iIAX9K_uRz&_nc_ht=scontent.fdet1-2.fna&oh=00_AfDyvQgGpp4aTckICxG-b82ml1-Pg7AY64xo07IvoVE2MQ&oe=651BE9A5.jpg
LED headlight on the driver side, halogen on the passenger:
383952666_10159917498408597_7565396845333488508_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=813123&_nc_ohc=Cdkhqxf5gbwAX88Z0vy&_nc_ht=scontent.fdet1-1.fna&oh=00_AfBSYpYWJPOlBdeT-IGRvtk5s_GDP87ATN-eOyT_0iTAeg&oe=651BF79D.jpg
383959864_10159917498773597_6476696376231672305_n.jpg?_nc_cat=110&ccb=1-7&_nc_sid=813123&_nc_ohc=fs05-dIsMbMAX-nYByk&_nc_ht=scontent.fdet1-1.fna&oh=00_AfACbKWpAmwkVUoga670L-NoXo0w7kMmG4C-mKc5R8AO2A&oe=651C079E.jpg
Both LEDs installed:
383964539_10159917500348597_7114604275459056417_n.jpg?_nc_cat=106&ccb=1-7&_nc_sid=813123&_nc_ohc=1neTSh3L3WIAX8iG62A&_nc_ht=scontent.fdet1-1.fna&oh=00_AfCFj6Jb1nIHdMhBqnda5xaNrPmHPrThSN3ihav-KVANcA&oe=651D4839.jpg
382841735_10159917501048597_4439684030450622568_n.jpg?_nc_cat=109&ccb=1-7&_nc_sid=813123&_nc_ohc=HGDVt1j_u_kAX-dybl0&_nc_ht=scontent.fdet1-2.fna&oh=00_AfA5kLjPebFWhBnxDPLiaiWzlM92k-e5pEFxadzL0IU5ow&oe=651CE8AC.jpg
384483427_10159917501218597_4356115855919076060_n.jpg?_nc_cat=107&ccb=1-7&_nc_sid=813123&_nc_ohc=YXk48RTAvKMAX-fOZ9T&_nc_ht=scontent.fdet1-1.fna&oh=00_AfCx_E_0dXUCIamLhOO2BlWEm9fN1QAMlkxIRwhUH-4kOg&oe=651D59E4.jpg
383972221_10159917501413597_3392798707386124026_n.jpg?_nc_cat=105&ccb=1-7&_nc_sid=813123&_nc_ohc=l1Lyi8QUJiwAX8V1RLn&_nc_ht=scontent.fdet1-2.fna&oh=00_AfDXZiV47hHdfZ_2hth3GUWfT6RJ1oh7EyjUosyc9tbq9g&oe=651C9D6A.jpg383985896_10159917501793597_6528995433379644147_n.jpg?_nc_cat=106&ccb=1-7&_nc_sid=813123&_nc_ohc=iVGXppR-QoMAX8_dEVL&_nc_ht=scontent.fdet1-1.fna&oh=00_AfDBAdb9gVKMFZlyTExhfrgA_dQmze3yXOEqLP0UW6-sbQ&oe=651D0E6A.jpg
383959533_10159917501903597_605991560461868303_n.jpg?_nc_cat=102&ccb=1-7&_nc_sid=813123&_nc_ohc=zQtUQlomCkMAX8nQAZB&_nc_oc=AQl2IYvHgfA7D4Rqkhwc09mdRWzmFjn9sw6NecEEmoIQOpyB-RvZOffgcOZuG1nIF6M&_nc_ht=scontent.fdet1-2.fna&oh=00_AfBwb1
384278467_10159917502048597_2388608801255911486_n.jpg?_nc_cat=103&ccb=1-7&_nc_sid=813123&_nc_ohc=8AJzF5QOlTEAX-pXmM-&_nc_ht=scontent.fdet1-1.fna&oh=00_AfA5tKWwdS9hEuh6ORyD0PtiKR9cHykMtK0KZvTFOkrv2g&oe=651C4E64.jpg
And then a nighttime comparison, without a car in the way (this just happens to also be about 25 feet, which will be handy when aiming):
Halogen low beams:
384741808_10159917751628597_2467183700179094995_n.jpg?_nc_cat=110&ccb=1-7&_nc_sid=813123&_nc_ohc=Egs4OFCKj98AX9YxCyB&_nc_ht=scontent.fdet1-1.fna&oh=00_AfANOGaVOiA06MR1iP4s-8_Qv2D2MYLcNv3bPseh3nqpbQ&oe=651D6A86.jpg
Halogen high beams:
383965655_10159917751693597_7159757971585054552_n.jpg?_nc_cat=110&ccb=1-7&_nc_sid=813123&_nc_ohc=lHwwd7j4RQ8AX_fIGzL&_nc_ht=scontent.fdet1-1.fna&oh=00_AfAF69ZdSsXD_rkqcV_PMj6ZiBwTApHEljdCekjnHkplbw&oe=651C5986.jpg
LED low beams:
383959246_10159917751743597_8555043922825075157_n.jpg?_nc_cat=108&ccb=1-7&_nc_sid=813123&_nc_ohc=Ef7tMQLuX8cAX9tEYXX&_nc_oc=AQnc2j3t7KUymSG2EYFQWy61DgTE4zBymlgjI7DtxjjwRdXNZKYnZ7w4DcXB6_dDkhY&_nc_ht=scontent.fdet1-2.fna&oh=00_AfD1C
LED high beams:
383979106_10159917752163597_6007129317044850904_n.jpg?_nc_cat=106&ccb=1-7&_nc_sid=813123&_nc_ohc=U7OuSWe72h4AX8S7NDP&_nc_ht=scontent.fdet1-1.fna&oh=00_AfD-tKqubnKaXloeZ-ggvOGOKPHPktrSPjfWhejiyVwpBA&oe=651BAF2B.jpgGone but not forgotten: 1986 Chevrolet Camaro IROC-Z
Yeah, I am really impressed with them - very well built and a hell of an output.
They actually make a similar light for 4x6 sealed beams, though I wish they came with the OE-style Fresnel lens...then again, hidden headlights make that a non-issue.Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
Knowing your love of the Q-Jet, is there any chance that you change the fuel filter on it? I ask because our friends at Rock Auto, in their wisdom, sent me a fual filter for a carb'd 305, when I clearly indicated mine was efi. It's going in the garage otherwise.DynoDave
Yup - the rebuild kit came with a new filter, and I actually pulled it last year or the year before to check and make sure it still looked nice and clean, which it did.
So you ordered the FI filter and they flat out sent you the wrong thing?Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
I occasionally go on little shopping sprees for the old cars when they are having close-out sales. I have the car on my list of cars, so they know the year/make/model and engine. In theory, it should show me only parts that fit my car. So I probably paid less than a dollar for this filter. Not a big loss. A lot of times they don't have a picture of the item. Just wanted to make sure I couldn't;t find it a home before tossing it in trash and recycle the box.DynoDave
