Dan's 97 Camaro part 2
  • #46
    Originally posted by DanDalessandro View Post
    This all started with just pulling the timing cover to replace gaskets. Then I got a new 24x kit for pretty cheap, then decided heads and cam.
    This is exactly why I didn't bother doing the oil pan, timing, and rear main gaskets when I had the engine out. I knew it would lead to a full rebuild of the engine, which would lead to some machine work. Might as well wait until I'm ready to tackle that head on.
    • #47
      Spec Stage 2 clutch kit, Spec steel flywheel, pressure plate bolts, and pushrods have been ordered.
      • #48
        So you've elected not to go the factory-correct resto route, then?
        • #49
          Naah. Car is getting dipped hot pink next!
          • #50
            sub'd, looks like you've got a good build going here!
            Originally posted by JasonH
            • #51
              The heads have been torque down and I'm going to set the lash and repin the harness hopefully Sunday after work.
              I also decided to use paint for grills on my timing cover lol. I actually kind of like it.
              • #52
                Looks like it's coming together! Have a date in mind you're trying to get it on the road for.
                • #53
                  Trying to get it running before my birthday which is July 19.
                  • #54
                    Do you have anymore big stuff left on the checklist or is it just finishing everything up? Looks like it shouldn't be any problem at the rate you're knocking stuff out!
                    • #55
                      The last things to do is:
                      Set lash
                      Put the motor all back together
                      Repin the harness
                      Fuel pump.
                      Then I can start it.
                      Last would be the clutch
                      • #56
                        Lookin good man!
                        • #57
                          Looks sharp!
                          1997 Trans Am
                          T56 swap. LS1 Cosmetics
                          • #58
                            Thanks Brian you coming over or what brah
                            • #59
                              As soon as you quit dinkin' off and get ready to fire it up!
                              1997 Trans Am
                              • #60
                                Look at them fancy bolts!
