Dan's 97 Camaro part 2
  • #31
    Do you still have the A/C lines? Are you saving them? I had a spare set that I cut the fittings off of with just enough of the tube left to fit rubber vacuum caps tightly over them. Clean look, no hassle.
    • #32
      I may have cut the lines already lol.
      Some progress is better than no progress.
      Had a rough time getting the fuel line off. That rubber grommet that is over them is rotted to all hell and it ended up falling off. Can I still reuse the lines or would that be a bad idea? I might just relocate them to make it look cleaner.
      • #33
        Intake off. Needs a deep clean on it.
        The valley was extremely clean. No sludge at all! Very surprised from a 111k mile car.
        Heads go on tomorrow
        • #34
          Hardly an update.
          Proceeded with removal of the timing cover removal. The hub was easy to remove and I was relieved.
          Timing cover popped off after I lowered the oil pan. I aligned the timing and pulled the cam sprocket.
          I believe gm spec is 1 inch of play in the timing chain. I have about half that.
          • #35
            Get this thing done this weekend! Weather is gonna get nice u will be stuck pedaling your ten speed around
            • #36
              The yellow look is due to the lighting. The pistons and walls were silver.
              • #37
                It was time for new headgaskets
                • #38
                  Glad you found that! Keep going man, we got some cruising to do!
                  1991 Camaro RS: "Tiny Turbo Mullet"
                  • #39
                    Did a thing today
                    • #40
                      • #41
                        That's a lot of santorum on one camshaft, probably a good thing you're swapping it now!
                        • #42
                          Assembly lube!
                          • #43
                            Spit will work too if you're in a pinch.
                            ohh wait you're putting that in your block, nvm.
                            • #44
                              Did more things. Need new head gaskets as the ones I got are fine, they were just a little bent on the edges and I'm not going to take any chances.
                              • #45
                                Pushrods have been ordered. Harness repin tomorrow
