I thought the A5 Astro kit was for the V8 trans, do they have an input shaft for the v6 cars?
Documenting my build : name my car!
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Here's one of my emails with TonyOriginally posted by hoogiesngrinderz View PostI thought the A5 Astro kit was for the V8 trans, do they have an input shaft for the v6 cars?
I went out and did some measurements after getting the Model Number off of your T-5.* I found that my Ford Mustang 5.0L Style Input Shaft would be the candidate I would have to use to make an input shaft for a 6 Cyl. Camaro.* I would have to modify this input shaft as the pilot diameter of the Mustang is larger in O.D. than that of the Camaro. In addition, I would have to cut back the splines to lengthen the pilot as your pilot is longer by .335”.* One thing I would like to see in picture form from you if possible is where the clutch disc actually rides on the input splines. I don’t think there will be an issue, as one of my customers in Atlanta has built Camaro 6 Cyl. T-5’s up with our Upgraded Gear Kits with no issues. But, I would still like to see the spline area for my own interest as to know where the disc slides back and forth.*
Sent from my LG-ls990 using Tapatalk
Enthusiast
- April 18th, 2012
- 336
- Spencer Bailey
- 1999 Trans Am
- Flint Michigan
- Manager - Wear Master
Now that's more like it!sigpic
99 Trans am
- SLP Air Take (LID)
- Ported and Polished Throttle Body
- LS6 Intake Manifold
- 1 3/4 Long Tube Headers
- 3" Y-Pipe
- 3" Magnaflow Catback
- Lower Control Arms
Soon
- Heads/Cam
- 3600 or 4000 Stall
- 3.73 Gears
