Originally posted by zeeman
View Post
"Shadowfax" - Jeremy's 15th Anv. Trans Am
a few posts back I posted something on the lines of needing to get the car out of the garage asap for a party, and Andy just so happened to have a low mileage 9 bolt that he offered me, so I sold off the posi stuff I bought, and just swapped in the 9 bolt instead."Project Shadowfax" <- Clicky Clicky
Got the torque arm bushing all installed, now its just a matter of getting the rear brakes back on. and the car will be good to go!"Project Shadowfax" <- Clicky Clicky
So.. I might be a little obsessive in my planning of this car haha..."Project Shadowfax" <- Clicky Clicky
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
what is that^91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Its a website/app called Trello, its a project tool, mostly used for a group of people to collaborate on projects together. I am using it basically for a tracking tool for my project so I know what is going on with the car and what is still needed to be done, its pretty handy.Originally posted by TylerT/AZ28 View Postwhat is that^"Project Shadowfax" <- Clicky Clicky
Post Whore
- 3000
- Tyler Porter
- student
looking into that for sure91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
hey [MENTION=1515]92conv[/MENTION] does your 84 have the "performance sound" option? I was curious how it worked, is there a button to turn the amp on? any chance you could take a few pics? haha"Project Shadowfax" <- Clicky Clicky
Originally posted by Speedfreak391 View PostHey Jeremy, Nice T/A! Glad that rear end worked out for you! Just let me know if you still are interested in that other stuff I offered you. I can help you with all of the ls swap info and even some parts that I have left over from my car.
Thanks Andy! sounds good!"Project Shadowfax" <- Clicky Clicky
The systems may have changed over the years (the switch most certainly would have with the '85 interior refresh), but my '88 has the Performance Sound system. It uses the on/off switch and slide control seen on the left side of this photo, just above the Goodwrench alarm keypad. They control a separate amplifier, and two 4" or so subs. Those subs, along with a 2nd pair of 4x6s (like the ones in the dash) are in the quarter trim, same place as a conventional stereo's 6x9s.DynoDave
Time for an update on the project.
As some of you may know, my wife and I just had our baby a few weeks ago. so it had put the car on hold because of money and time. now that things have settled down some I made some decisions.. I decided that the most important thing for the car right now is to just get it going, and not worrying about the future build. So I sold the 5.3 and bought the last couple things to get the car drivable.
The stuff that was keeping me from moving forward was the rear brakes and battery. So I went ahead and bought all new brake stuff since it was ALL worn out.. even the calipers were seized, I know this would have been a decent time to upgrade brakes.. but I decided that since at this point the car is stock anyways.. that I would just stick with stock replacement calipers. ultimately the 9bolt and rear brakes will be upgraded down the road.. so for now this works.
I put the new battery in and started her up last night, and boy was it a pain... the Q-Jet is just not wanting to cooperate with me.. I messed with it forever last night and its just giving me issues..
I think I may just give in and try to find a holley/intake for a deal.
So hopefully I get a little time this weekend to get the last few things buttoned up and maybe I can actually get a drive in before the snow comes."Project Shadowfax" <- Clicky Clicky
Ok.. sorry for no updates recently.. the car has been sitting for a bit untouched.. I feel horrible.. but with the M&G coming up soon.. I decided to list out what needs to be done to get the car on the road..
- adjust/bleed rear brakes (they are on, just need the lines hooked up, and bleed. these are the old delco calipers, so they need adjusted via the e-brake cable)
- swap on the new tires (I have these sitting in my garage, just need mounted and balanced)
- buy/install windshield wiper motor (in case it rains)
- figure out how to keep t-tops for leaking (in case it rains)
- buy/install fan switch so I don't overheat
- install torque converter lockup kit (already own, just need to install it)
- install carpet and interior (won't be perfect but at least it will be together)
- block off cowl opening (so that water doesn't drip down on engine/distributor if it rains, the power bulge vacuum stuff is missing, so its just an open hole)
- replace qjet with edelbrock carb and intake (own the new carb already, the qjet is warped and leaks gas and probably vacuum leaks)
- replace and hookup heater core (this isn't needed, but will be nice to have done)
- replace stock muffler with flowmaster ( I have one laying around)
- insure/plates/tags
the list seems kinda big.. but really for the most part this stuff is pretty simple.. just need to get it done.. I have about 4 months to get this stuff done.. and I have no excuse not to have this on the road this year!!"Project Shadowfax" <- Clicky Clicky
Ok, So I am finally starting back on this car lol!
I cleaned up the garage so I can actually do work out there, so I am finally getting this thing going lol!
I picked up an edelbrock 2101 intake manifold for $25, the guy even threw in the intake gaskets too, so that is good!
basically I just need to start knocking stuff off the list.. this weekend I should be able to at least get the car back on all 4 wheels. maybe I'll buy some beers and see if anyone wants to come over and knock out these little things with me.
I'll probably start on the edelbrock carb rebuild here in the next couple days (tearing down and soaking it)Last edited by Jdseibe; March 21st, 2016, 12:10 PM."Project Shadowfax" <- Clicky Clicky
