"Shadowfax" - Jeremy's 15th Anv. Trans Am
  • hoogiesngrinderz
    replied
    I'd replace it while you have easy access, aren't they about $40? Cheap insurance...have a heater core spring a leak is NOT fun.
    Leave a comment:
  • Jdseibe
    replied
    So I am placing my order to get my interior stuff put together..
    -front/back carpet set
    -SEM primer/dye (still figuring out which color I need to order)
    -POR-15 - small can to take care of a few small floor board rust spots under the carpet
    also picking up a new alternator and power steering pump (both of which are bad) power steering pump leaks something terrible when new fluid is put in and the alternator was the cause of my electrical draining issue.
    should be swapping the transmission soon too! I'll be having a lot of updates when work actually starts happening!
    side note.. I'm assuming my heater core is bad since its not hooked up, do you guys recommend me replacing it now since the interior is already apart or should I wait to replace it when I start digging into all the wiring for my LSx swap?
    Leave a comment:
  • Jdseibe
    replied
    lol no point in making the car stop better if it never moves [emoji14]
    Leave a comment:
  • hoogiesngrinderz
    replied
    But they will be cheap! Honestly they were the best upgrade I've made to my IROC, but now I've gone to huge brakes
    Leave a comment:
  • Jdseibe
    replied
    Brake upgrade is not even on the list right now lol
    Leave a comment:
  • hoogiesngrinderz
    replied
    I'll sell you my LS1 front brakes
    Leave a comment:
  • Gregs_gsxr
    replied
    SO...your thinking Big brake upgrade then.
    Leave a comment:
  • Jdseibe
    replied
    So I think for right now since spring is coming soon, that I am going to stop focusing so much on the LSx swap and start working on just getting the car driveable for this summer. I'll be ordering my carpet here soon so I can at least attempt to put the interior together!
    Leave a comment:
  • s.reef
    replied
    Good intake, just went with a blower
    Leave a comment:
  • Gregs_gsxr
    replied
    Originally posted by s.reef View Post
    Wow, I didn't know LS1 intakes were going that high these days. I sold a few a few years back for $75-$100 I wanna say. I have a brand new LS3 intake, rail and injectors and can't get rid of it for $300
    yea there is a reason your selling it...cause no one wants them
    Leave a comment:
  • s.reef
    replied
    Leave a comment:
  • Jdseibe
    replied
    Leave a comment:
  • Jdseibe
    replied
    so what is a good price for a complete LS6 intake with injectors, rails, TB and all?
    Leave a comment:
  • Gregs_gsxr
    replied
    I hope you snagged up that intake. I'll send you some pics of the pistons tomorrow sometime. Ill text you about some other details too
    Good lucking finding a set of 243/799 heads for under $400
    Leave a comment:
  • Jdseibe
    replied
    So I think the plan for the engine is currently going to be the following.. unless I can get a steal of a deal for 243/799 heads soon
    - Cleaned, Rebuilt 862 Heads with a valve job and upgraded springs (what recommendation on springs do you guys have? do I need a spring kit?)
    - Stock Rocker arms
    - Upgraded pushrods (chromemoly?)
    - ARP head bolts
    - New headgaskets (stock thickness?)
    - Engine will be cleaned up, either a honing or boring/honing
    - Flat top pistons (are the stock pistons forged or hypereutectic? what should I upgrade/swap to?)
    - Piston rings? preference?
    - Should I replace crank/cam bearings?
    - ARP rod bolts
    - TSP 224r Camshaft
    - LS1 intake\injectors\rails\throttle body (figured I could upgrade these later, for now just to get it on the road)
    - Racing Innovations Long tube headers
    - what other gaskets will I need? timing chain? oil pan? let me know what your thoughts are?
    I am hoping to be at about 10:1 - 10.5:1 compression ratio I think
    thoughts?
    Leave a comment:
