I think its got a vacuum leak somewhere. The idle goes up and down some times. Perhaps its o2 sensors?
Nate's 1998 Z28 Project
- Greenville, MI
- Die Maker
Could be a vacuum leak, the PCV systems on these cars are know cause problems. Could also be from throttle blade position (high/low IAC counts), wrong RAFIG values (since M6 cars don't use RAFPN table), and/or the spark swing values (+/- too high) overcompensating at idle.
An afternoon with EFIlive and a WB02 setup would probably help a great deal, and it doesn't cost a dime with 98's. I might be able to borrow the setup again, but last time I borrowed it for FAR too long due to all the issues I had with my blue 98
I wouldnt buy spohn stuff after the problems Michael had with them on his iroc-Joel
- Greenville, MI
- Die Maker
Nope.Originally posted by JoeliusZ28 View PostI wouldnt buy spohn stuff after the problems Michael had with them on his iroc
It wasn't just my a-arms, either. Quite a few people have tried to bring it up with the people at Spohn (even Steve himself) but everyone gets brushed off.
UMI from now on with the IROC. The 98 has BMR products on it, rear sway bar is starting to shed it's powder.
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
So what "supporting mods" do you currently lack to take full advantage of your cam?
He needs more than a single 2.5" muffler for starters. That thing is breathing through a straw.-Joel
exhaust and a steet/dyno tune. I am not so held up on the current tune but between the exhaust, heads, and some Ac Delco o2 sensors I think it has quite a bit left in it.Originally posted by alone_and_insane View PostSo what "supporting mods" do you currently lack to take full advantage of your cam?
Several people dyno over 400 rwhp. I don't believe my heads will support that but theres more in it.
If you seen the exhaust this car has on it, most of you would shit. Literally you would just crap at the ridicules-ness of it.1998 Chevrolet Camaro Z28 - 6 Speed
- Greenville, MI
- Die Maker
Like I said, I have a cheap SLP Loudmouth setup
What headers and y-pipe do you have? Might have overlooked that
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Got any pictures of the exhaust? I bet mine's more janky than yours.
