Nocooler's 00 Firebird
  • Nocooler
    replied
    Jim isn't pulling a Larry on us is he?
    Larry's was sucking the pan dry and acting like it was a 6000 stall.
    Leave a comment:
  • dawdaw
    replied
    I think you'll be happy with an fti converter, some converters out of the box are spot on some aren't... its for sure not uncommon to pull a converter a couple times to get it just right. Ive got an fti in mine and will see next week how it drives. Jim's though was seriously, seriously loose and was a joke. Im sure he will only need to pull it least another dozen times anyway good luck getting it going, im sure youll be happy with hiw much it picks up the first half
    Leave a comment:
  • Nocooler
    replied
    Thanks for the feedback guys.
    Leave a comment:
  • erk2581
    replied
    Originally posted by kammi10 View Post
    that was the old ridings one that was all sorts of F***** up
    No way?! lol
    Leave a comment:
  • kammi10
    replied
    Umm didnt yours goto like 6000rpm
    Leave a comment:
  • 1BADAIR
    replied
    Leave a comment:
  • kammi10
    replied
    Originally posted by FASHOOTER View Post
    Missed this thread, I think u will enjoy the auto. Are u planning on running a FTI converter? Be warned they do set them up very loose! I have sent mine back 2 times now.......wish I would have kept my YANK
    not mine.. mine has been spot on since the day i got it.. works perfectly.. its going to be getting sent back but by my choice bc it will need to be tighter for more boost
    hell even Dr Phil liked it when he tuned the car..
    Leave a comment:
  • erk2581
    replied
    I have an FTI converter and could not be happier with it.
    Leave a comment:
  • Nocooler
    replied
    Efficiency wise they were told my HP and nitrous plans. Just put it back in this morning back to the dyno Thursday. Not pulling it out again.....nice guys to deal with but I would recommend YANK......I should have kept the YANK
    Interesting - I see guys like Carter01 setting the stock bottom end LS1 nitrous record with FTI convertors.
    Guess I'll have to think it over some more. Thanks Jim
    Leave a comment:
  • FASHOOTER
    replied
    Leave a comment:
  • Nocooler
    replied
    FTI is one of the companies I'm considering.
    Is it loose stall wise or efficiency wise?
    EDIT: did you have them set it up for the motor or the spray?
    Leave a comment:
  • FASHOOTER
    replied
    Leave a comment:
  • Nocooler
    replied
    Nearly $900 of parts on the way from summit
    Flex plate
    ARP fp and tc bolts
    Trans cooler & lines
    shifter
    bmr 4l80 crossmember
    4l80e mount
    transgo hd2 kit
    trans filter + gasket
    All I should need now is:
    Internal trans wiring harness
    Speartech conversion harness
    Dipstick and tube
    Convertor
    Need to shake the money tree more
    I'll probably come out to $2300-$2400 for the entire swap.
    Leave a comment:
  • Nocooler
    replied
    Larry what sfi flexplate did you end up running?
    The TCI looks better than the alternatives but it's big $$$
    Leave a comment:
  • 1BADAIR
    replied
    they need to make a 90 harness so you dont have to mod the brace. I looked into making one or moving the wires to another location
    Leave a comment:
