2000 pontiac trans am project build
  • #31
    To answer your question Rolo, Friday morning i'm taking the car over to get the rear end looked at.
    • #32
      I know this mod has been done alot but what all envolve removing the air/egr system? any one have pictures i looked around on ls1tech but the all the links with pictures dont work anymore.
      • #33
        Basically just removing the lines and disconnecting the pump. Takes no more than 30min.
        If you plan on doing this before your LT's then you will need block off plates. Pump is connected by 4 bolts I believe. I had a hard time with one bolt.
        And a plug for your manifold.
        • #34
          i'm doing it at the same time as install. so i just need the EGR intake and manifold block offs?
          • #35
            If you are doing it when you install your LT's then you will only need 1 block off and that is for the intake.
            You will not need manifold block off since you have race headers. I believe the size for intake is 1 3/8, which you want a freeze plug.
            • #36
              Not that this is incredibly detailed, but may fill in a couple gaps:
              http://www.mifbody.com/vbulletin/sho...l=1#post788099
              • #37
                OK. Thanks guys.
                • #38
                  A 1 3/8 expansion plug is what you need for the intake manifold after the EGR delete. They sell them at Autozone.
                  • #39
                    Re: 2000 pontiac trans am project build
                    Why did I say freeze plug. Go to sleep rolando
                    Yea the plug should be couple dollars at most.
                    Why not just get an ls6 intake or better
                    • #40
                      I might. But I'm way over budget on the car for this year
                      • #41
                        For the YEAR it just started
                        • #42
                          Already spent $4500 and it only April.... I want to drop in a 9" rear end next winter so I'm saving up for that as well. Now if I get my promotion at work then I will have to reward myself. Maybe a fast92 and tb
                          • #43
                            Took my car to AL's trans and gear this morning, had a new pinion seal and my diff cover put on.
                            Also pic on the new rotors
                            yea i know i'm missing a screw in my center cap. the DA at discount didnt put loctite on the scews after he balanced the. got new screws this morning at mid states bolt.
                            • #44
                              Nice, how much did it cost you to replace the seal and have the cover put on?
                              • #45
                                $115 did it in an hour. Al is a good guy!
