^ This. I would save for a drag bar tho. The new(ish) BMR extreme bar is super light compared to the other brands and is priced very similar.
MWC bar is suppose to be 10-15lbs as well - but if you need one in a hurry good luck. I'd like to ditch my spoon bar for one - but the car needs $$$ else where.
Couldn't tell you. Mine has not been out since I have put it on..
Any anti roll/drag bar will be fine... you will see wear and tear on the rod ends of the links because of it being a solid bar. Not really a big deal, how many street miles a year.
Bmr,umi,spohn,Wolfe,mwc,racecraft,trz all make good vars
What do you mean umi is more adjustable and less stiff? You either set the rod links neutral or preload them, There isn't any other adjustability on an anti roll bar.
Make a pass at the track and see how it tracks. If it wants to steer right lengthen your passenger link, if it want to steer left shorten the passenger side. Set the load on them with a driver that weighs close to you
