jderry's 1996 Camaro
  • When I ran bias-ply ET Streets I started around 15psi and worked my way down in .5psi increments.
    • I thought you were running ET Street radials for whatever reason.
      • So I am going back to Milan this weekend, hoping to spray, not sure what shot yet, 50-100.
        1996 Base Model
        +2 cylinder mod
        • Shoot it with 100. Shut it off and pull the plugs. Baby steps are what keeps engines alive
            What is a good gap to start with? Would it be a good idea to use the 100 unleaded I have been, or mix some 110 in with it?
            1996 Base Model
            +2 cylinder mod
            • Originally posted by jderry View Post
              Not sure on the gap. Why are you using anything other than 93? Not that its hurting anything but I doubt you need it.
              • Set the gap around .035 - use a br7ef
                Hit it with 100 - 50 is just wasting time.
                Use 93 octane and pull 4-6* and let it eat it.
                2000 Formula
                fixed slow junk
                • 100 is nothing really but Jeremy has given you very safe advice, have fun.
                    Alright, that sounds good to me, what should I set my window to? Shift points are @ 6500, I usually just leave off the brake, 3600 stall converter, and rev limiter on my tune is 7000.
                    1996 Base Model
                    +2 cylinder mod
                    • Does the convertor flash to 3600? How much does it drop on the shift?
                      I'd probably start with the window @ 4000-6800 if you want to spray through the shifts. It's harder on the trans but will run quicker. If not set it 50-100 before the shift point.
                      Once you get a good pass or 2, play with lowering the activation point down 200rpm at a time - but don't go below 3000-3200 rpm.
                      2000 Formula
                      fixed slow junk
                      • So as of now I have the 685 setup as follows
                        Mode 1: RPM Limit
                        Mode 2: AUX RPM limit
                        Mode 3: 4.0 degrees AUX retard
                        Mode 4: .1 degree Start retard
                        Mode 5: 4000 RPM Window start
                        Mode 6: 6800 rpm Window stop
                        1996 Base Model
                        +2 cylinder mod
                        • Got out to Milan today, they were only doing 1/8 mile due to weather (some bs)
                          On motor ran a 8.0250 @ 88.39 mph with a 1.91 60' spinning
                          On the 100 7.1778 @ 96.59 mph with a 1.61 60' spinning also
                          1996 Base Model
                          +2 cylinder mod
                          • 7.teens is low 11's
                            Sounds like it ran well.
                              7.teens is low 11's
                              Had that "oh shit" feel to it, car got kinda loose at the line, I have a video I can upload in a few.
                              1996 Base Model
                              +2 cylinder mod
                              • Here is the digital camera video, still have to convert and shorten the gopro one
                                1996 Base Model
                                +2 cylinder mod
