Originally posted by TylerT/AZ28
View Post
1992 Camaro- Road Racing on a budget
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
what flavors91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
They were both IROC hoods. The original blue one was damaged in the accident. The replacement red one was propped up and the corners were submerged in water for over 5 years. I plan to use that SMC hood so I scrapped both of the hoods along with the 1985 Trans AmOriginally posted by TylerT/AZ28 View Postwhat flavors
Btw - did you want me to change the thread title to 1985 instead of '92, or did you want to create a new thread?- Brian Meissen
Yeah, hes going to have to.Originally posted by Gregs_gsxr View Postgoing to put a new core support on the 85?sigpic
Doesn't matter to me - if you want to keep this thread going to show the progression from '92 to '85 I can just rename the thread
The engine in the 85 Iroc would only run off of starting fluid. I checked fuel pressure, then confirmed the harness was supplying power to the pump. I then began the process of removing the fuel tank to replace the fuel pump. Upon removing the tank I relized I am going to need more than a fuel pump. The smell of the old gas gave me a headache and I was surprised the tank didn't leak with the amount of rot inside the tank. It was very clear why I wasnt getting and fuel pressure. The tank and sending unit are junk. The good news I can use the tank and sending unit the from 1992 RS (with a higher pressure fuel pump)photo (17).JPGphoto (18).JPGphoto (19).JPGphoto (20).JPG
Hope to have the 1992 gas tank, assebly installed by mid week.Last edited by bri2203; July 7th, 2013, 11:04 AM.
