1992 Camaro- Road Racing on a budget
    There goes the "budget" to this build! Doesn't Austin's car have spacers? I think you'd bet ok with the right adapters, not the "shim" style spacer
    does this depend on what size spacer, or just at all?
    I was going to run a 3/8" spacer on my z06 wheels, but ill probably road race / autox on the 16s anyway.
    I been doing a little reading and spacers are OK according to the NHRA. I doesn't mention adapters...
    "Wheel spacer permitted. Spacer to be either hub-centric or lug-centric and must fit with minimal clearance to retain concentricity. The wheel
    spacer must not reduce the minimum permitted thread engagement below the limits established by fastener diameter
    . (See example as stated above.) No stacking of wheel spacers allowed."
    • any more opinions on wheels?
      If use F-body 98+ brakes I can still use 16s. If I used C5 Brakes I have to use some form of 17.
      The weight increases!
      I WONDER what this is...
      • Originally posted by hoogiesngrinderz View Post
        I wanted to go get a set of these
        http://www.ebay.com/itm/275-35-18-Ho...9ff3f3&vxp=mtr
        Edit: These are 18" tires, didn't see any 17" from him
        Holly schnikes! Thanks for the link!
        • wonderbar
          00 Tahoe Z71........Stock
            Brian these are what Austin was telling us about and uses...
            • Originally posted by TylerT/AZ28 View Post
              wonderbar
              Quite a handy bar!
              I'll have to check this car out on Friday.
              • What the hell is a wonder bar?
                • it ties the frame rails together at the front of the car, really helps out
                  • Yup.
                    Here's an aftermarket one, making it easier to distinguish.
                    • I assume they fixed the need for that with the release of the 4th gens, because ive never heard of one
                      • I'd assume that is because of the switch to rack and pinion. The power steering boxes caused the front frame to flex a bit. They also came out with braces as well.
                          Yeah. The wonderbar is essentially an STB, but for the bottom of the car, instead of up top.
                          • i just welded a pipe in between the frame rails right next to the radiator area on my old 85.
                              not a strut brace, k memeber braces.
                              • A big thanks to Brent for letting me borrow the lip rolling tool. Both rear 1/4 have been rolled!
