11 is gonna cause issues. 10 is plenty
1998 Camaro Z28 NBM LS1(der what I was thinking?)
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
The widest they come is 9.5", which has a 3" lip. I can do that with the stock width axle. 5" is the goal, and the more I look at them the more I lean away from themOriginally posted by TylerT/AZ28 View Postpics of the mesh
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
do the billet specialties if you can swing it. not liking the other ones.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
As of right now I'm pretty limited in wheel selection. Probably $1500 on the low end for built to order offsets like this.
Mag G
Dagger G
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
So long 6.0, hope it works out well for you Ricky!
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
6.0 is coming back, turned out not to be what either of us thought it was. I'm going to go pick it back up next week hopefully, along with the LS1 accessories and the transmission lines.
I do need help with some last little things. I need two of the 10mm bolts that hold the lower airbox, a set of clamps for the intake duct (only have one, the smallest one), and the grommet for the IAT sensor (assuming there should be one there). I also need one of the lower cushions for the radiator. How does the plastic cowl in front of the windshield attach? Oh, also two of the plastic pins that hold the air baffle to the air box.
A couple o2 sensors, some radiator hoses, and two u joints are on my parts store list. After I figure out what route to go for an engine it's just a matter of putting it back together. Cosmetic stuff can be done after I get it road worthy
Post Whore
- 3000
- Tyler Porter
- student
how is it not?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
LQ4 not LQ9, stored improperly by previous owner - dirty cylinders with some rust on the walls and water in the pan. I'll strip it down and send it out to see what my machinist has to say.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
I have all sorts of bolts, I just want the correct OEM ones for air box
I need two more of these bolts holding the air box:
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
If Lowe's has them, I'm not against using them. Everything I have found so far is SAE
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Ricky, I'm thinking Monday afternoon I will try to head over - if that works for you and the rest.
