1998 Camaro Z28 NBM LS1(der what I was thinking?)
  • #46
    It's an LQ9, no less than $999
    If you find a LQ9 with less than 36k miles on it for cheaper that that, well then I might reconsider.
    • #47
      But it rattles like a Powerstroke......
      8 hundy
      2015 Silverado
      • #48
        I'll think about it. At that price it would be the block and heads - a couple sensors and that's all. I have DBW throttle bodies, two wiring harnesses, and one ecm that I'd sell for extra, as well as 4 truck intakes/rails/injectors
        • #49
          All that extra stuff doesn't do anything for me. Got an F body harness' or a PCM? 4l60e?
          2015 Silverado
          • #50
            f-body stuff I have is going into the Camaro, the rest is truck related
            • #51
              I already have an LQ9 in my truck so I don't need any of that. Want to sell it or what?
              2015 Silverado
              • #52
                For $800 I'll pass and keep the car build on schedule, I need this car moving on its own ASAP.
                • #53
                  So, how do the transmission lines run on these LS1 cars?
                  • #54
                    trigger pulled on the LS1 accessories and intake
                    • #55
                      What do you mean?
                      They run from the trans to the radiator back to the trans like pretty much every other automatic car or truck?
                      • #56
                        Wow! that interior is hit! I would put some of that lightweight carpet in, or hell even over top of whats in there.
                        edit: and holy engine collection!
                        • #57
                          along the side of the oil pan. little clip on the front right of the pan
                          • #58
                            If you need parts picked up from Wixom, let me know, I live about 10 minutes from there, I can buy/pick up whatever you need and hold onto it (as long as it's not something huge?)
                            1998 Camaro SS Bullseye Turbo
                            • #59
                              Greg is grabbing all the LS1 accessories and intake for me, I just need to figure out when I can get to the other side or have my friend from Dearborn transport it back to Lowell.
                              I've been looking for lines and I've been seeing different fittings. Not sure if they are hard lines or not, haven't been under an auto LS1 car before.
                              Interior is getting gutted. Carpet is coming out and getting the Bissel hot water treatment. If it doesn't clean up - new carpet. If I can't find used seats I will just order the $500 covers from Hawks.
                              Parts!!!
                              • #60
                                Do you plan on picking up an LS1 water pump or just beating the truck one with a hammer?
