I dunno if you have Aco Hardware on your side of the state, but I found them to have a tremendous amount of hard-to-find bolts when I needed them recently.
1998 Camaro Z28 NBM LS1(der what I was thinking?)
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
None around here. Just Ace, True Value, and the big box storesOriginally posted by birdie2000 View PostI dunno if you have Aco Hardware on your side of the state, but I found them to have a tremendous amount of hard-to-find bolts when I needed them recently.
All depends on what time. I'm tied up after 6 with school and in the AM I usually work. But keep me updated.Originally posted by hoogiesngrinderz View PostRicky, I'm thinking Monday afternoon I will try to head over - if that works for you and the rest.2015 Silverado
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
I'd leave here at 2pm, arrive at Flint Airport between 4 and 4:30.
Should I load up the cherry picker? I don't have the enclosed trailer yet so it might be kind of tight with an engine, picker, and rear end in the back...but I only have to get to Warren to drop off the rear
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
That should work, as long as you're not in the SS
I'll be heading over in the '02 Z71.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
I'll bring the picker. Plan on 4:30 at the airport, I'll let you know if it's a go - just waiting to hear back from one person, the rest are scheduled in.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Got the 6.0 back, it's on the stand that I got from a friend. #1 and #5 have questionable cylinders, the rest are dirty. All are currently soaking in Marvel's Mystery Piss (aka oil)
Pictures! 'Cause I know you all like them
#1
#5
#4 has an odd look to it
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Plan for the 6.0 is to clean up the cylinders with a 320 grit flex hone, maybe run a ridge reamer prior to piston removal. Moly ring set, stock MLS gaskets, new OEM head bolts, used Z06 cam. I plan to eliminate the piston slap by getting the skirts coated (free/super cheap - it's good to know the VP
) and I'm really liking the idea of doing .030 cut on the 317 heads.
Rumors of you getting rid if this...
I think you need to sell all of your 6.0 and 5.3 stuff. Find a complete ls1&trans and mod that. IMO. You'll get the motor in much quicker and easier. Then fix it up to the poin you can sell it and go with something different or make it into a nice car again.2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
I have everything I need to put it back together. This car just doesn't excite me much and the exterior/interior need a ton of work.
I don't need four cars, but it's growing on me though. I guess I should say I don't need 3 project cars
I'm going to buy Andy's grey leather seats instead of getting these recovered. If I can't get the carpet clean then I'll replace it and be done with the interior. If I keep the car it will get a the cammed 6.0, Sunoco hood, narrow rear end, and maybe big brakes.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Just purchased a 320 flex hone, torque angle meter, moly rings.
Can't decide on head gaskets. I can get the LS3 GM OEM for $76 or Fel-Pro 9199PT (don't think they are MLS) for $36, or spend a bit more on the Fel-Pro 1041 to bump the compression a little
Do you have all the other bolts/gaskets you need? I found the bundles from Texas Speed to be cheaper than buying individually.Originally posted by hoogiesngrinderz View PostJust purchased a 320 flex hone, torque angle meter, moly rings.
Can't decide on head gaskets. I can get the LS3 GM OEM for $76 or Fel-Pro 9199PT (don't think they are MLS) for $36, or spend a bit more on the Fel-Pro 1041 to bump the compression a littlesigpic
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
I have one set of head bolts but I need another to get both engines put back together. I'll look into their prices. Thanks!
