Originally posted by Gaspo
View Post
Gaspo's 99 trans am project
thanks for the info on the heads! good to know.
what is the trunion upgrade?
Dave, its definitely a possibility. i'll PM you again98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
Trunion kit replaces the needle bearings in the stock rockers.Originally posted by Gaspo View Postthanks for the info on the heads! good to know.
Do a search on LS1tech you'll find all the info you need.2000 Formula
fixed slow junk
how hard is it to install the heads when the engine is in the car? when i did heads on my last car, the engine was out.. any tips/hints?98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
are they already off? installing them is not that bad really just scrape the deck with a plactic ice scraper or something that won't damage the aluminum. then place the gasket on and the head and torque the bolts in sequence. The biggest pita about it is probably installing the power steering resivoir as one of the bolts your only able to turn 1/4 or so each time.Doing less with more
ya i remember the power steering deal last time i did it. they are almost all the way off. just wondering about having to deal with the cowl. do you recommend using RTV silicone too or no?Originally posted by DETROITMUSCLE View Postare they already off? installing them is not that bad really just scrape the deck with a plactic ice scraper or something that won't damage the aluminum. then place the gasket on and the head and torque the bolts in sequence. The biggest pita about it is probably installing the power steering resivoir as one of the bolts your only able to turn 1/4 or so each time.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
