    Sometime this summer when were at woodward ill drop my calipers off to you... you need to get me that rebuild info!
    It's rather easy, and I am learning easier ways the more I do it as well. Its rather cheap to do as well, no reason to buy replacement calipers again!
    another Big Thanks to BigJon, coming over when he was tired and lack of sleep, we bled the brakes yesterday and started body work again...
    Fenders are in primer and so is the ac delete panel. Its one step closer...
    • Looking good Darren!
      ..............____ .......
      ________|___\____
      |__(O)__|____|_(O)|
        [ATTACH=CONFIG]54548[/ATTACH]
        If you want to do the rebuild for me id be fine with that too. Im in no hurry to get them installed, my hawk pads on the LT1 calipers are still working great and have tons of life left.
          I got everything from O'reilly's, seals are $5.99 for the front (you need 2) and if you are doing rear then you only need one front seal kit for the rear... Really that is the bare minimum that you need, because you can reuse the sliders and caliper bolts and clips... I bought all new... including bleeders. Still cheaper then new caliper. I have also had good luck sandblasting the clips, and the bolts and making them like new again, so that is a option as well.
          Are LS1 brakes that much of an upgrade compared to LT1?
          • Good to know. And yep, single piston vs dual piston calipers.
              Ah so the same thing compared to thirdgen then, single piston.
              • Looking good man!! Keep up the good work!!
                02 Camaro SS LE
                Stock for now
                15 Silverado Crew
                2/3 Drop/22" OEM wheels/Magnacharged/Corsa/Tuned
                11 Chevy Tahoe
                Stock
                • Bump
                  • Last edited by Darren; June 25th, 2014, 01:08 PM.
                    • Well I drove the car today... Learned a important thing.... My brakes do not work
                      Sent from my iPhone 5 on iOS7 using Tapatalk
                      • We will get her done soon enough
                        • Hopefully you were able to stop??
                          • Yes Jon slowly but surely it's getting close. Id assemble it tomorrow if it was drivable.
                            Yes B I was able to stop. I had some brakes combined with the e brake. I hope they just need to be bled... Again
                            • So, important question, is the brake boosted hooked up?
                              91 Firebird 305 TBI
                                Excuses
