  • my 92 sat like that with no engine and lift off the ground as high as possible
    00 Tahoe Z71........Stock
    • There where these isolators, or compressors or something installed on the springs when I bought the car, I have no idea what they are really called or what they really are. However Brian noticed them one day while over and he thought they may have been restricting the spring or actually making them "space" out actually making the car ride higher. Well one night jon and I got bored and CUT them out, Now just noticing the result of the action in the front.
      Now whats the easiest way to remove these front springs going to have to do some cutting or ordering, one of the two.
      • Get yourself a set of Moog replacement IROC springs if you want a great affordable spring with a factory ride height.
        • I'm a little confused about what you have cut out...got any pictures? I've only seen the small isolator on the top of the spring.
          I've always raised the car up and put jack stands under the frame rails. Then I pulled to front tires off, compressed the spring by the lower a-arm until it barely lifts the car. I strap the spring in with a chain or good rope so it cannot fly out, unbolt the strut and lower the jack. There are write ups all over for this. Or you can get the spring compressor
          • Just trying to understand - so cutting something out actually is making the springs taller?
            • We cut out something that looked like a spring compressor that had the springs compressed from sec coil to the bottom coil
              • From what I gather that they are talking about, it was something like this
                • Ah... Yeah that'd probably cause it to sit higher.
                  • That's it grandpa..... Made it sit lower that what we cut out now looks higher
                    • Originally posted by jetice View Post
                      [ATTACH=CONFIG]41775[/ATTACH]
                      yep those are them, what are they called or what did you search to find this picture?
                        https://www.google.com/search?sugexp...w=1536&bih=764
                        • hmm thatd certainly lower the beast. to take out springs jack up the car all the way get as much tension off the lower control arm as you can, id take off all the springs and such and then use a crowbar and your foot and the gracefully pop out
                          • Nice to have some friends who are willing to lend a helping hand...
                            • Wow. I wish I had a team like that. My car would actually be able to make it to the meet and greet.
                              • Originally posted by Curt_irocz View Post
                                Mine was looking like it could make it, not now tho
