  • Thanks Guys!
    Check these out...
    So wet sand is next on this part of the car... Link me to some products to use to polish the car please someone tell me a good process here. Also Joel where you serious about letting me borrow a buffer? If not I need to get one, suggestions?
    • Buy some 2000 paper let it soak for a good 15 min before using it. Use water with soap. Like car wash soap. Sand untell all orange peal is gone then 3000. Then a 3m white foam pad with some fine cut compound. Then black 3m foam pad with swirl remover. Don't wax it!!!!!
      • what buffers should I be looking into?
        • I have a makita. It's awesome. IMO they are the best. Dewalts are nice too but are noisy.
          • Yes I was serious about letting you borrow the buffer! You'd be in for another $400 by the time you bought all the pads and polish!
            I normally use meguiars because its convenient. But, 3M and Wizards is also good if not better.
            You will really only need 3 polishes. Fine cut (I would even try to skip this), Swirl Remover, and a final polish. I have wetsanded my car before with 2000 and then skipped right to a yellow pad (harshest foam) with swirl remover. If you can do that it'll be a breeze. I can provide you the final polish since i have gallon of it and that stuff goes forever.
            With both wet sanding and buffing. You are ALWAYS better using too fine of a paper/polish than you are too harsh. When you go too harsh, you get to do an entire additional lap around the car correcting all the hairline scratches and swirls. You are much better off working slower with a fine stage, than fast with a heavy stage. In the end, you'll get done faster going slower
            • wow darren looking awesome,u did a gret job with that car congratulations,will be watching this one,cant wait to see it all color sanded and buffed.
              • im with joel i always started off with 1500 then went to 2000 grit. i also use dawn dish soap mixed in the water when wet sanding it works the best at not letting the sand paper clog up. as far as sand paper i love useing black ice i think its made by 3M it dont crease very easy.
                a soft block of rubber or even a cheap dollar store spung works well for wraping the paper around and helps the paper fallow the contours of the car vary well. stay away from the edges and never sand using your fingures or your hand as it will leave inpression in the clear. im sure someone who paints or details will have a better process than mine, all i know is my way has deffenatly yeilded some great results.
                with my car i cheated alittle when i had all the orange peal knock'd down i loaded the car up and to it to detailer and let them wheel it
                • is it just me or is this thing flat white? looking at the pic in the daylight on FB it doesn't appear glossy from the clear at all.
                    Orange peel probably gives it that appearance
                    • Thanks Joel I'll have to meet up with you sometime soon. I'll be wet sanding next week. Any rule in how fast I have to polish or can I set sand the whole car and come back and polish it?
                      Day time pictures!
                      • You could sand it today and polish next month if you wanted so no.
                        • Nope take jons car for example... His had been wetsanded and it could be brought back at any time.
                          I'd like to give you some pointers before you start the wetsanding, give me a call sometime.
                            Ill call ya sunday or monday evening I am heading up north in a few minutes so I wont get back to the car before then.
                            • Looks good! Still looks grey though.
                              j/k
                                Check my thread
