my 92 sat like that with no engine and lift off the ground as high as possible
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
There where these isolators, or compressors or something installed on the springs when I bought the car, I have no idea what they are really called or what they really are. However Brian noticed them one day while over and he thought they may have been restricting the spring or actually making them "space" out actually making the car ride higher. Well one night jon and I got bored and CUT them out,
Now just noticing the result of the action in the front.
Now whats the easiest way to remove these front springs
going to have to do some cutting or ordering, one of the two.
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
I'm a little confused about what you have cut out...got any pictures? I've only seen the small isolator on the top of the spring.
I've always raised the car up and put jack stands under the frame rails. Then I pulled to front tires off, compressed the spring by the lower a-arm until it barely lifts the car. I strap the spring in with a chain or good rope so it cannot fly out, unbolt the strut and lower the jack. There are write ups all over for this. Or you can get the spring compressor
Just trying to understand - so cutting something out actually is making the springs taller?- Brian Meissen
We cut out something that looked like a spring compressor that had the springs compressed from sec coil to the bottom coilThe Original
From what I gather that they are talking about, it was something like this
Ah...
Yeah that'd probably cause it to sit higher.
That's it grandpa..... Made it sit lower that what we cut out now looks higherThe Original
yep those are them, what are they called or what did you search to find this picture?Originally posted by jetice View PostFrom what I gather that they are talking about, it was something like this
[ATTACH=CONFIG]41775[/ATTACH]sigpic
https://www.google.com/search?sugexp...w=1536&bih=764Originally posted by Darren View Postyep those are them, what are they called or what did you search to find this picture?
Post Whore
- 3000
- Tyler Porter
- student
hmm thatd certainly lower the beast. to take out springs jack up the car all the way get as much tension off the lower control arm as you can, id take off all the springs and such and then use a crowbar and your foot and the gracefully pop out91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Nice to have some friends who are willing to lend a helping hand...sigpic
Wow. I wish I had a team like that. My car would actually be able to make it to the meet and greet.
Mine was looking like it could make it, not now thoOriginally posted by Curt_irocz View PostWow. I wish I had a team like that. My car would actually be able to make it to the meet and greet.
