i wish i had 3k
Project White Out 2011
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
- Greenville, MI
- Die Maker
Greg, I started to gather information for you setup. Then I remember that I never asked what injectors are you using. Your truck harness will either have MultecII or EV6/UScar connectors if it was a flex fuel vehicle.
ah shit, I may have to send you a pic, i want to say it was ev6 cause Im using 42 lb ford mustang injectors'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- Greenville, MI
- Die Maker
It isn't a big deal, I just ordered new connectors for the Impala harness. $60 for them and the open barrel crimp tool.
BTW, that is a ton of injector if you plan on running at 58psi, They would be closer to 54lb. It is entirely possible to run them at 43.5 psi though. I have stock 2000 LS1 26.6lb on my 6.0 w/ TR224 cam and long tubes. They are a little small though, they hit 85-90% duty cycle around 6000 rpm.Last edited by hoogiesngrinderz; October 10th, 2013, 09:06 AM.
I figured they were free and right off the dyno at ford with a few pulls on them. I hope they work'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
3rd gen secrets, sorry Brent….
however lets say Im looking for mandral bent tubing in a big size know anyone that has some or can bend it
[MENTION=1023]OVRKILL[/MENTION]'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- 3000
- Tyler Porter
- student
theres a scrap bin full of 4" 75 wall at work if that helps you at all.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
This is where my exhaust came from. Really great to deal with and seem like they genuinely care about doing the job right.Originally posted by OVRKILL View Postsigpic
Obsessed- June 6th, 2012
- 505
- Brian
- 1991 Camaro RS/1991 Camaro Z28
- Wixom Michigan
- Truck Driver
picked up a hell of a deal on 411 cpm yesterday, should make tuning and wiring way easier now.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
