Also how did you mount your shift light? I bought one too figuring on using a hose clamp around the column, but the blinker stalk box thing gets in the way.
Charlyne 95 Z28 M6
- Lowell, MI
- Meat Processor
I don't think there is a wrong was to put that emblem on
Looks like the angle of the camera is causing an optical illusion
That intake needs colorsigpic
Because of the angle and v-shape of the bumper, it is a one-way fit, and people screw it up all the time because it doesnt look "that bad" applied the wrong wayOriginally posted by hoogiesngrinderz View PostI don't think there is a wrong was to put that emblem on
Looks like the angle of the camera is causing an optical illusion-Joel
I remember the first time you ever told me about the upside down and I thought you were on crackOriginally posted by JoeliusZ28 View PostBecause of the angle and v-shape of the bumper, it is a one-way fit, and people screw it up all the time because it doesnt look "that bad" applied the wrong way
I can't believe that front bumper has clearcoat pealing, it was painted by a very reputable body shop only 3-4 years ago
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
The bumper is peeling because there was a incident in storage a few years ago, involving bumping a Porsche Boxer.Originally posted by my95z28 View PostI remember the first time you ever told me about the upside down and I thought you were on crack
I used double sided tape to put it on top of the column.
Yes I plan on running her this year. Ran her last year. Best of 13.87 at Lapeer with a 2.2 60. Plan on running Milan and Ubly. Hopefully will see 12s on motor.
I'm pretty sure I put the emblem on the exact same way it came off, cause I lined up the marks that were left behind :/
Yes the intake does need color but I just got here driving again and don't wanna tear the intake off just yet! Haha.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
How solid is it? I was hoping to figure out something better than that-Joel
Lurker
- March 13th, 2010
- 3476
- TJ
It doesn't move at all. Only thing is with the wire pulling down on it, it would tip up a little bit. I accidentally knocked it off today. I might come up with something else, but as I said it doesn't move.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Mines a little bigger and the mount isnt very big so im concerned double sided tape isnt gonna cut it. Hmm...-Joel
Lurker
- March 13th, 2010
- 3476
- TJ
Why did you get such a big shift light?!?!?!
Mine adjusts on the top of the light. How does yours adjust?
So I can't mount mine in the A pillar maybe you can mount yours there?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
In that case I won't because of you!
Took her for another spin today.
Got her on the freeway.
80+ got vibrations, feels like the driveshaft.
I have the pinion angle at 0 currently. Will adjust tomorrow and try again and see.
Currently scanning over a data log.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
its a digital tach also, but same form factor as your shift light.Originally posted by Fox Slaughter View PostWhy did you get such a big shift light?!?!?!-Joel
Lurker
- March 13th, 2010
- 3476
- TJ
PSHHHHHHHHHH. What do you need that for? Keep her screaming thats all it needs.
Well I adjusted the pinion angle to -1* today and adjusted the u joint bolts. Vibration has now moved up from 80 to 90. Going to adjust the pinion angle some more.
EDIT:
So I just read suppose to do the pinion angle off the transmission angle using the crank pulley angle. My crank pulley is saying 2*. So the trans is pointing up. Original motor mounts and trans mount as far as I know. I think I should change these out as its causing the motor to dip.
Working on the tune, has some lean spots yesterday so did a quick flash, now I have some rich spots. Work in progress.
Heres the first wash of the year, street trim, 4x4 stance anyone?
DSCN0246.JPGLast edited by Fox Slaughter; April 2nd, 2013, 06:13 PM.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
