DSCN0238.JPG Front runner wheel gap. Might raise her up a little more. Shes got mad rake right now haha. DSCN0239.JPG New exhaust on and tunnel mount torque arm. DSCN0240.JPG Gap in the front on the rears. BFH. Tube LCAs non adjustable :/ DSCN0241.JPG Rear gap. DSCN0242.JPG How low the front end is sitting currently.
Originally posted by Yoshi94
Yupp thanks for the help.
Won't start though haha.
Got 45psi at the rail, she turns over just won't fire.
Car looks good, i like the rims. I have 28's and did the bfh... I'm going to probably roll my fenders now to cause i have adjustable shocks and i'm sure they'll cut my new tires. Are you going to roll your fenders? get rid of that tiny little sway bar out back too! that car if it hooks is going to have a ton of body roll.. Also what do you have for springs in the rear, it may just be the photo but it looks like the A$$ of the car sits pretty high.
Do you have spark? If the car ran before and now that your adding a 2 step, i'm sure it's in your wiring you did.
I need someone to come crank the car so I can check for spark. The 2 Step is not wired up right now, but it did start before and I haven't messed with the wiring since it was last started up.
Haha when I took her around the block on the slicks the speedo was way off. Thought it was cause I programed them for my street tires. Put the street tires on took another spin and a some logging. Speedo still way off. Just looked I said it was an automatic trans not manual doh!
So need to reprogram that.
The very few cells I hit only one on the left was slightly rich and two on the right. Gotta do more logging though.
Overall she feels solid with the new shocks and coilovers. Heard some clunking, need to investigate. Put insurance on her as I planned driving to work with her but not with that clunking going. Plus pinion angle is currently 0 so I wanna adjust that further to probably negative 1.5.
