Charlyne 95 Z28 M6
  • sorry im not popular enough to be with the "in crowd" on this thread
    1997 Trans Am
    T56 swap. LS1 Cosmetics
    • If we get busy enough we will be building an oven big enough to do rear ends n maybe even bike frames probably by end of summer but we are gonna b cone sponsor first n get some stuff in order first
      • Nice Jon.
        Well I am starting to remove the trans this looks like its going to be fun.
        Originally posted by Yoshi94
        • Who needs a lift? Ok I wish I had a lift haha.
          • Pressure Plate and clutch disc.
            • We used a flat board on my jack and put the trans on the board.
              • Mine was pretty stable on the jack.
                By flat board do you mean like a sheet of ply wood or a 2x4 though?
                • So I got the clutch in, bell housing in but with the joys of not having instructions and never putting an aftermarket bell housing on apparently it all has to come back off.
                  Joy joy joy.
                  • Out of curiosity, why does it have to come back off?
                    The instructions for the McLeod were there but left a lot to be desired because they weren't specific to the LT1 bellhousing.
                    • The starter did not fit so I am going to grind the opening.
                      But apparently you need to measure the run out to make sure the bell housing is in line with the crankshaft other wise it could cause transmission damage.
                      Guess you are suppose to do it with any new bell housing.
                      The Quicktime had no instructions.
                      • Originally posted by Fox Slaughter View Post
                        Do you just want the torque arm or do you want the mount weighed also?
                        EDIT:
                        The bathroom scale says 20lbs for the arm and 10lbs for the mount. So 30lbs total.
                        UMI says on their setups its about a 3 - 4lbs difference plus stronger.
                        Mine came out to 32.85lbs FWIW
                          Thats fully assembled also. Only bolts it didn't have are the ones that bolt it to the car(4 crossmember and 2 through the diff)
                          • Yeah I didn't weigh it with the bolts.
                            Apparently Chromoly isn't that much lighter haha.
                            • The way I understand it, chromoly isn't inherently all that much lighter, but it is stronger which means you can use less wall thickness to get the same strength which then will give you your weight savings. On pieces as small as that I'd think even with a stronger metal there's not that much margin to make the wall thickness much smaller, hence the relatively small weight difference.
                              • Originally posted by birdie2000 View Post
                                Hey don't you have some bell housing to check?
                                Yes what you said is entirely true.
