sorry im not popular enough to be with the "in crowd" on this thread
Charlyne 95 Z28 M6
If we get busy enough we will be building an oven big enough to do rear ends n maybe even bike frames probably by end of summer but we are gonna b cone sponsor first n get some stuff in order firstThe Original
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Nice Jon.
Well I am starting to remove the trans this looks like its going to be fun.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Lurker
- March 13th, 2010
- 3476
- TJ
Lurker
- March 13th, 2010
- 3476
- TJ
Mine was pretty stable on the jack.
By flat board do you mean like a sheet of ply wood or a 2x4 though?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
So I got the clutch in, bell housing in but with the joys of not having instructions and never putting an aftermarket bell housing on apparently it all has to come back off.
Joy joy joy.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Out of curiosity, why does it have to come back off?
The instructions for the McLeod were there but left a lot to be desired because they weren't specific to the LT1 bellhousing.
Lurker
- March 13th, 2010
- 3476
- TJ
The starter did not fit so I am going to grind the opening.
But apparently you need to measure the run out to make sure the bell housing is in line with the crankshaft other wise it could cause transmission damage.
Guess you are suppose to do it with any new bell housing.
The Quicktime had no instructions.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Mine came out to 32.85lbs FWIWOriginally posted by Fox Slaughter View PostDo you just want the torque arm or do you want the mount weighed also?
EDIT:
The bathroom scale says 20lbs for the arm and 10lbs for the mount. So 30lbs total.
UMI says on their setups its about a 3 - 4lbs difference plus stronger.Doing less with more
Lurker
- March 13th, 2010
- 3476
- TJ
Yeah I didn't weigh it with the bolts.
Apparently Chromoly isn't that much lighter haha.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
The way I understand it, chromoly isn't inherently all that much lighter, but it is stronger which means you can use less wall thickness to get the same strength which then will give you your weight savings. On pieces as small as that I'd think even with a stronger metal there's not that much margin to make the wall thickness much smaller, hence the relatively small weight difference.
Lurker
- March 13th, 2010
- 3476
- TJ
Hey don't you have some bell housing to check?Originally posted by birdie2000 View PostThe way I understand it, chromoly isn't inherently all that much lighter, but it is stronger which means you can use less wall thickness to get the same strength which then will give you your weight savings. On pieces as small as that I'd think even with a stronger metal there's not that much margin to make the wall thickness much smaller, hence the relatively small weight difference.
Yes what you said is entirely true.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
