my egr is deleted and I still nock down 26 on the highway. 6 speed though
1996 Camaro Z28 LT1 Project
Hell i get 26 highway cammed without EGR. If youre that worried about mileage, just sell the carOriginally posted by nascarnate326 View Postmy egr is deleted and I still nock down 26 on the highway. 6 speed though
Post Whore
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
It's not that I'm worried about mileage as much as it is that I'm concerned why it's not running as efficiently as it should be...a 10 mpg difference is pretty substantial.
I agree 16.xx is aweful mileage mostly hwy. If i kept my 1993 z28 at 70 the best I could get was 21. A few things are against you
- we are now using winter blend fuels
- automatic transmission
check for vacuum leaks
is your lock up converter working?Last edited by bri2203; November 10th, 2012, 07:06 AM.
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
I would assume the TC is working correctly...heck, it's almost brand new, just like the trans rebuild. How would I be able to tell if it's not locking up? Could it potentially be an ATF issue? Shortly after I filled up with gas I checked the ATF level and I was running a bit low, so I added some. Would adding too much maybe have something to do with it?
You have a 4 speed transmission. Count each shift, after the 3-4 shift at ~45-50 mph you should notice the RPM's dropping, like another gear change almost. That is the converter locking.2015 Silverado
What ricky said. The other thing you can do is once at cruising speed (at least 55) pump the throttle as much as you can without initiating a downshift. If the tach holds a constant rpm (like a manual transmission would) the converter is locked. If the rpm fluctuates a few hundred rpm with your throttling , it isnt locked. Beware when doing this test that some pcms are programmed to unlock when you let off the gas entirely, so it will take a couple seconds to lock again once you are throttling steady.... In other words when youre pumping the gas, dont let off completely or it will unlock anyway.-Joel
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
I did this driving down 275 the other day. RPMs stayed pretty constant, so I suppose that means that it is indeed locked.Originally posted by JoeliusZ28 View PostWhat ricky said. The other thing you can do is once at cruising speed (at least 55) pump the throttle as much as you can without initiating a downshift. If the tach holds a constant rpm (like a manual transmission would) the converter is locked. If the rpm fluctuates a few hundred rpm with your throttling , it isnt locked. Beware when doing this test that some pcms are programmed to unlock when you let off the gas entirely, so it will take a couple seconds to lock again once you are throttling steady.... In other words when youre pumping the gas, dont let off completely or it will unlock anyway.
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Look who's baaaaaack
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Are we talking about the pile of grass clippings? I wondered where those went.
Look good sir.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
It got dropped off at the exhaust shop yesterday. The guy who is building the exhaust does a lot of road racing, and he recommended that I get a tubular Torque Arm. Would this be a good investment? I can get a used UMI Adjustable unit for $275 shipped.
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Picked it up from the exhaust shop today. Got a Magnaflow muffler and an O2 sensor bung installed, and got the exhaust tips finally lined up right (they were always a little too low and crooked). I also ordered a new driver's side power window switch bezel. I'd like to also get the windows tinted before the MSU Car Show on the 21st, but idk yet if that's gonna happen.
