1996 Camaro Z28 LT1 Project
  • Rainy day, so after watching the USA women's team win gold (), I spent about an hour and a half going to three different hardware/auto supply stores looking for thread chasers and caps for the AIR fittings. Went 0 for 3. Where do you think I could find these? I need the chasers more than the caps.
    Originally posted by JasonH
    • I typically used taps after powder coat but I'm very careful with it. Chasers are hard to find - I guess Sears did/does sell a "rethreading kit" for $50
      • Summit has inexpensive thread chasers. Might be too late now, but if you get them early enough ground shipping will get it to you next day 99% of the time.
        • is 1/4-18 thread the same as 1/4 NPT?
          • 1/4-18?? Never heard of it.
            Also, I'd just go with the PCM4less tune. There's been 1000s of LT1s that have done this, they've gotta have it pretty well figured out by now.
              the 18 is the number of threads per inch. And that's sort of what I was thinking with PCMforless, but I would still feel more confident with a legit dyno tune. Jim (birdie2000) suggested maybe I see about asking the tuner to at least remove EGR from my PCM with a deposit toward a full tune later, so the car will at least be running. Thoughts?
              • what is the actual difference between a tap and a chaser? Could I use a tap to clear the threads?
                • Originally posted by alone_and_insane View Post
                  I've done that before - you have to be careful not to cut up your original threads, though - a chaser won't do that.
                  • I think I'm gonna end up just using a tap. I can't find a 1/4" pipe thread chaser ANYWHERE
                      Just be careful that you stay in the original threads and that the tap doesn't force the debris into the threads and mess up the threads.
                      • Dunno if I missed it, but are the threads messed up or is there just crap in them?
                        • I just got the intake manifold powdercoated, so I'm thinking that debris got in the threads. I had a really hard time getting any of the fittings started, and the one I was able to get going I sheared off.
                          • Didn't work for very long today, but I actually made a little bit of progress. I managed to remove the EGR pipe, I finally got to it using 9 inches of extensions and a universal joint haha. I also got the other AIR fitting off and got a couple chunks of the AIR pipe cut out, and I got caps to go on the AIR fittings on the headers. Looking forward to getting a lot done tomorrow!
                            • I may have a bit of an issue. I unplugged my spark plug wires when I was going to replace the opti...when I was plugging one of them back in, one of them didn't want to click back into place. I took it back off to look at it, and this is what I found:
                              can I pull the middle of it back out? Or do I have to get a new wire?
                              • Thats the coil side right or spark plug side?
