I couldn't really feel where the line from the back of the intake manifold goes to...the AIR pipe should be pretty easy to remove, it's pretty flimsy. I've had a hard time getting the AIR fittings off the headers though too. Gonna have to use some more WD-40 I guess
1996 Camaro Z28 LT1 Project
Post Whore
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
So I screwed up...I took a look at the my Haynes manual to see if there were torque specs on the rockers, and I found that it says to make sure you put the pushrods and rockers in their original places...yeah, didn't do that. How, well, screwed am I? How can I make sure each pushrod and rocker is in its proper place?
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
also, is it mandatory to do a valve adjustment when reinstalling the rockers?
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Yesterday between asking questions, I painted my alternator.
Taped up:
Primed:
Paint & Clear:
finished:
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Using all new lifters? If so, orientation doesn't really matter. I put the oil holes facing the rear facing the flow for poops and chuckles.
Rockers and pushrods should have stayed together, but I highly doubt it's going hurt anything. Each cylinder (one at a time) will need to be at TDC of compression stroke to properly set valve lash. There is a way to do 1/2 at one time and then rotate the crank in order to do the other half.
Baloney, me and my buddy did heads & cam in an MSU apartment parking lotOriginally posted by alone_and_insane View PostHow do you remove the crank pulley bolts without the pulley turning? I tried putting the car in gear, but that didn't work.
I'm actually seriously considering abandoning the effort to replace the opti. It's just to big of a job to do in my apartment parking lot, especially considering I'm not 100% sure my opti is bad.
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Ok, let me rephrase it then. It's too big of a job to do in an apartment parking lot if I want to drive this thing to the Dream Cruise, especially considering I'm not 100% sure the opti needs to be replaced.Originally posted by JoeliusZ28 View PostBaloney, me and my buddy did heads & cam in an MSU apartment parking lot
Otherwise, I was feeling kind of lazy today and didn't do any more outside on the car. All I did was give the throttle body the same paint job as the alternator.Last edited by alone_and_insane; July 30th, 2012, 07:53 PM.
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Disaster.
Tonight I was working on putting fittings back into the intake manifold while watching the Olympics. Then this happened:
I'm in a state of disbelief right now. I can't believe that happened...and I have no idea how the heck I'm supposed to be able to fix it...
You should be able to get an easyout to grab it then screw it out of there.sigpic
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Do you know what the hose that fitting is for goes to in the first place? I don't recall at the moment. If it's something I'm deleting I could just block it off and call it good.
Post Whore
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Yeah I already figured out that hose is for the brakes, but that picture will be super helpful, thanks Brian.
So where can I get an easy-out?
O'Reilly or AutoZone should have something that would work. If not the local Sears or ACE Hardware store will.- Brian Meissen
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Any auto/hardware store should have them. What concerns me is that it looks like it snapped down in the threads a little...try to find an easy out with a slight taper and not much larger than the opening so you don't catch the intake instead of the broken part
