1996 Camaro Z28 LT1 Project
  • it's been a while, but I'm resurrecting this thread. I'm probably going to do some work replacing the water pump in the next couple of weeks. Do you guys have any tips/cautions I need before I get underway?
    Originally posted by JasonH
    • Do your best to not let the coolant spill all over the optispark. There's two bolts that if you unbolt first the coolant will drain out and not get all over the optispark. I *think* it's the outermost bolts (bolt #40) as seen in this picture:
      • wrap a towel aronud the opti. wrap a towel aronud the opti. wrap a towel aronud the opti. wrap a towel aronud the opti. wrap a towel aronud the opti. wrap a towel aronud the opti. wrap a towel aronud the opti. wrap a towel aronud the opti. please man ive wasted 2 optis myself and watch several people waste optis casue they didnt listen. it takes 1 minute to grab a towel and wrap it around the opti and pull it back off once you pull the pump out of the way and get it clean. to me its definately worth the little bit of time and 5 dollars youll spend on a towel to waste.
        94 V6 A4>>>>LT1 M6>>>>>>383 M6 13.1 @ 109 2.2 60' Sold/Stripped
        94 Z28 383 LT1 A4 SNAPPED CRANK
        1992 Camaro RS 305 700r4 Convert.
        1986 Dodge Ramcharger 318 Dually Rear, Camo paint. Scrapped
        1993 s10 4x4 5spd 4.3 on 31s awaiting a lift. [COLOR=rgb(0,0,0)]traded for...[/COLOR]
        1998 Jeep Grand Cherokee 4.0 I6 getting 3in lift and 31s within a week or two
        "Life is full of decisions, You make them and don't look back"
        • After you drain the coolant from the radiator. pull the 2 bottom bolt on the water pump that will drain the coolant from the heads and part of the block. thus not getting coolant all over opti. behind the pump.
          • well it took about 6.5 hours, but I got that water pump replaced today. I sure am glad that's over with. After I leave for school, my dad's going to re-attach the intake and take it to the shop to get the transmission issues figured out (doesn't shift into 4th), then to take it back to the shop that did the AC back in May, because it quit working 2 weeks after it got fixed.
            In other news, I was kinda pissed when I crawled under the car for the first time in a couple months and found my new ceramic-coated headers looking like this:
            It's even all the way down to bare metal in some spots, and surface rust is already showing up. Grr...
            • Did you put the headers through the heat cycles?
              Under the installation notes:
              http://www.holley.com/31132FLT.asp
              • Originally posted by jetice91 View Post
                thats for new motors though. his is not new.
                • What brand headers?
                  • headers are PaceSetter. Also, I got them lightly used, not brand new. This flaking is only at the ends. There were no signs of damage to the finish anywhere else. And yeah, my motor has 140k on it, therefore not new.
                    also, do want:
                    http://emblempros.com/inc/sdetail/7986
                    • you need to contact the company that said they are ceramic coated, those are painted, thats all you got ripped
                      99 Buick Regal GS- New DD
                      SOLD-1967 Buick Skylark
                      • And that's why I went with the LPP Stainless Steel Headers. I'll sacrifice a day of "customizing" to get LPP headers to fit so I don't have them peeling and rusting within a few months. Easier to install, faster to break down... harder to install, last longer... Pick your poison.
                        • well I bought them used from a private party on Ebay for $285 shipped, so at least I didn't blow $500 on these or anything. There's no way I'm going through the hassle of replacing these, so what can I do to control the damage?
                          • Take them off & get them coated sounds like the best bet... Or be done with it, sell them for cheap & get new ones
                            • and BTW the TA door sills will not look bad on your car but you have a Camaro, its your choice though...lol...j/k
                              • the headers are fine, they would take many years to actually rust through. Run them for a few then remove them and recoat them over a winter. Nothing to worry about.
