Looking good, bud!!
Phantom's LS1 Computer Swap
West Michigan Pontiac Club
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
I actually used a small steel chisel and taped it out from the bottom (me laying on my back).Originally posted by ThreeHonks View Postnice. how did you remove the crank key? just take some vice-grips to it?
Worked well
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Well I got a bit more done today
While I was at work I removed the shaft and bearings out of the water pump.
Anyone know how to tell if you water pump is bad?
Well let me show ya
This baby wasn't feeling to well
Anyone wondering how to remove these parts you must 1st press the shaft out from the front of the pump (impeller facing up) then press the other bearing out from the back.
And you get this
Like I said a few post ago if I got the parts for the rear that would go back in 1st before anything so that is what I did tonight.
Rear Housing and parts
Relocation brackets
I hope I have some time tomorrow to stick the rear back under the car??
looking great kyle i cant wait to come and check it out will be funThe Original
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
I'm using a Cloyts timing set.Originally posted by ThreeHonks View Postlooks great.
what timing chain set are you going to use??
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Don't look like I'll get back to this till Sunday
Put the new seals in the Timing Cover and plugged the water pump hole but it's not pic worthy
Also got the computer back from Baker all bench top programed and ready to go
that sucks how ur son has a good b-dayThe Original
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
alright!
I did some double checking today on the harness to make sure things were cool.
They weren't be cause my car is a 93 :/
95-97 have a C105 plug and my 93 don't so with some MORE searching on Shoebox's site I was able to move the needed pins into the C100 plug.
This is only needs to be done because my car is a 93!
From what I can tell if you plan on doing a 94 you will also have to do the same because the C105 plug didn't start till 95.
That is about all I got done today!
Rear will go back in tomorrow than I'll start on the motor again.
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Progress thus far:
I got the water pump drive hole plugged and seals in as well as the cam sensor bracket and 24x pick up.
Water pump and relay
New IAC holder from TPIS so I can upgrade to the 95+ IAC that is in my harness
Then engine wise I got the Crank Timing gear put on as well as the 24x wheel
I still have to take a little off the Crank key so the Hub slides back.
The 24x wheel is a loose fit and needs the Hub to keep it in place.
I plan on having the motor all buttoned up by the weekend and have the PCM and harness in by Monday or Tuesday.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Nice progress Kyle.sigpic
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
It's way to slow for my liking but it is progress non the less.Originally posted by Plum Nuts View PostNice progress Kyle.
If I didn't have to do the rear I would have been done by now but that is ok.
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Well things have been busy!
For starters I lost my job so that whole week was a wash, really sucks!
I did have a wire switched on my PCM but I fixed that.
I'm excited to say though that my car fired on the 1st try!
A real bummer is that my radiator has a hole in it so I have to wait t ill Monday to get her fixed
So any how back to my install.
I started back up with the timing set and getting the cam sensor attachment assembled.
A note when putting the timing set back on:
You will have to put the cam sensor pickup on with the bolts 1st or you will not get it on.
You must also drive back or cut your cam dowel so it don't protrude and get picked up by the cam sensor.
Once you have the cam sensor pick up on you will have to use the bolts to pull it back on.
New Uploads 126..jpgLast edited by Phantom409; April 3rd, 2010, 07:52 PM.
