Phantom's LS1 Computer Swap
  • #31
    This guy had to do it but I don't have my car home yet to look.
    Post 206:
    http://www.camaroz28.com/forums/show...55#post5927455
    • #32
      Originally posted by ThreeHonks View Post
      Also, what are you doing for the grounds, since the LS harness has seperate grounds
      Sorry, I'm not skirting this question.
      I actually missed 2 grounds on mine
      The LS 1 does run separate grounds for the MAP, TPS, IAT, and ECT.
      There are pins to ground them in the LS1 PCM.
      You have to rewire the grounds separate to the LS1 PCM.
      So LS1 pins need separate grounds run because they are not there in the LT1 harness:
      Blue 53 (auto only)
      Blue 54
      Blue 61
      Blue 80
      Added to original post.
      • #33
        sounds like you know what you're doing! I could see your car picking up a ton of power with this conversion and a good tune on it
        • #34
          soooo, you're taking an lt1 harness and converting it to an lt1 harness that runs off of an ls1 computer?
          ASE Certified Automatic Transmission Mechanic
          I would rather push a Chevy than drive a Ford
          Remember folks stop lights timed for 35mph are also timed for 70mph.
          94 Camaro Z28 LT1 396 sigpic
          • #35
            No... just modifying an LT1 harness by repinning it. You will totally ditch the opti and end up with an LS-style ignition with 1 coil pack per cylinder. Opti is totally gone
            • #36
              Ahhhhhhhhhh gotcha very nice
              • #37
                Got more parts
                So here is the Opti replacement bracket w/ cam sensor, 24x Reluctor, Crank Sensor & a 24x TB plate
                Here is what the back side of the Opti bracket looks like
                I haven't had a chance to redo my grounds yet but when I do I'll post that data up.
                Car will be home on Wed. weather permitting
                • #38
                  Like Ryan said I'm taking a LT1 harness and repining it into a LS1 computer.
                  This will totaly eliminate the Opti and give me the coils from the LS1 god's
                  And I'll be going from like 16 bit's per sec to 24 bit's per second in computer speed
                  • #39
                    Update on grounds:
                    I finished up my grounds just to find that I had a few more than I thought
                    LT 1 pins Red 1 & Clear 32 are a Black w/ White stripe wire that needs to be grounded separate.
                    I took these and will ground them to the block with an eyelet.
                    LT1 pins Red 18 and Blue 1 are a Tan w/ white stripe and don't need to be touched and will ground to the factory position on the block by the drivers head.
                    EFI Connection supply's (4) PCM pins in there kit:
                    Coolant Temp Ground - I followed this wire to a junction and clipped it and then extended the ground to the PCM pining it to LS1 Blue Pin 80
                    TPS ground - This was grounded when I followed the LS1 Pin-out sheet so I didn't have to mess with it.
                    IAT - Did the same with this wire, followed it to where it joined the junction and clipped it, extended it and pined it to LS1 Red pin 57.
                    This pin is also comes up more than once on the pin-out pg.
                    It's LT1 pin Black 16 so watch out for it.
                    MAP - This was pined with the EFI Pin-out sheet but did need to be clipped and joined half way.
                    This Ground was shared and in a Black w/ Yellow Stripe Junction (may not be the same on your car) in the harness and was with the 2 A/C grounds.
                    By clipping all the grounds and making the separate the A/C plugs had no ground so I clipped it off
                    Rejoined them and ran a ground wire to ground them.
                    So I should be ready
                    • #40
                      so the harness is totally done now?
                      • #41
                        Please tell me you're soldering the connections
                        • #42
                          I was thinking the same thing. All this time and effort and you're using just standard butt connectors? At least go with some heat shrink butt connectors!
                          • #43
                            I would definately go back and solder all connections and use heat shrink over soldered connections. Crimp connections are very risky because of heat and cold expansion and contraction and different metals. wire=copper crimps=alum. Kyle that just my opinion, I would never trust crimp connectors.
                            • #44
                              Never had an issue with crimping. Its not like its a winter car or anything. Maybe he is doing it for a test then going to solder it? Lets not draw conclusions.
                              • #45
                                having a stereo blink out is a little different than having an engine doing that...
