Purple People Eater!!
  • 11.1:1? Psh
    91+ octane on a LT1 will do 12.5:1 with a good tune.
    You've gone big on the cam, go big on compression 12.1:1
    Then you'll walk all over Joel.
    What who said that?
    Originally posted by Yoshi94
      11.1:1? Psh
      What who said that?
      Haha i'm not really competitive i just like going fast and having fun. And Joels car will always be cooler to me. And the problem is the valve to piston clearance ill run into going that high with compression
      • Piston to valve clearance?
        Psh, guys run higher compression with that with SR cams in the .7xx.
        You're just scared!
        SCAREDIE CAT!
          You're just scared!
          SCAREDIE CAT!
          Im just going off what my shop guy says lol but know you got me wanting to ask him about solid roller
          • I would go big on compression before cam fwiw
            • I am going to build the block laying in the garage as a SR because its only a Weekend Warrior/strip car now.
              So adjusting lash is no big deal.
                He said it will end up being 10.75:1 and that if we go 12.1:1 i would have to run 110 race gas. And i found out today that my stock crank is junk so the forged 3.75 crank and forged rods and pistons got ordered today there goes another couple grand lol
                • not true, you can push 12:1 if not 12.5:1 out 93 octane on an EFI setup if the tune is dialed in precisely. I have 11.5:1 with no issues. You can get close to 11:1 just using impala gaskets.
                    That's what i thought! Maybe its different with other sbc's? Should i just tell him to build it to have at least 11.5:1? I mean i'm building a fully forged 383 with fully ported heads and that big voodoo cam. I Mean ill be honest i know higher compression helps but i don't know alot about it. Is it good if i wanted to spray eventually?
                    • shouldnt hurt, youd just need a cooler plug.
                        that was another thing i have been meaning to look into what is a good plug? I honestly always just pick up the best one from the parts store
                        • Originally posted by Purple94Z28 View Post
                          I believe there is a rule of thumb for determining the best plug to run, but I use TR6s in mine with the 11.5:1 compression and it likes those better than the stock plug which would compare to a TR55.
                          • I'm thinking so i dont go to crazy i will prob go with the same compression as you Joel and run tr6's. I don't want to go over 12 cause i dont want to run into tuning issues.
                            • I think thats a good choice!
                              • Purple People Eater!!
                                Sounds like youre going down a good road! When I comes down to the time for my engine build ill be following Joel's setup VERY closely
                                1997 Trans Am
                                T56 swap. LS1 Cosmetics
