Purple People Eater!!
  • Originally posted by QuickTop View Post
    Sounds like youre going down a good road! When I comes down to the time for my engine build ill be following Joel's setup VERY closely
    I know Joel and his car have inspired a lot of my car and his faith in the lt1 is a key factor in me not having swap'd to lsx lol
    • Re: Purple People Eater!!
      Oh you will young padawon. Its just a matter of time.
      • Wish I clicked on this thread earlier.
        I have a slightly bigger cam on my 355 with 11:1
        LT1 intake will move the powerband up but the 383 will mellow the cam out.
        Edit: I think my IROC is slightly less duration but more lift. With a good tune you will be fine! Planning to run cats?
        • No sir it already has full stainless exhaust with long tubes off road 3" y pipe into a dynomouth catback.
          • Yeah thats a good point, the 383 wont make that cam so brutal to live with and the extra torque of the stroker wont make it seem so useless at low rpm. Should be a good combo!
              Sweet! That's what the machine shop said! I hope it's a good street/strip set up and it doesn't do to bad on the freeway, I plan on putting a lot of miles on it this summer if all works out okay. Cause I've owned the damn car for 4 years and only put 9k miles on it. And we bulled around with the idea of solid roller why I talked to him yesterday and he talked me out of it cause if I wanna drive it a lot he said I will not enjoy re-setting lash every couple weeks/months. And I agree so it looks like plans now are fully forged 383 with splaye 4 bolt caps, 11.5:1 compression with fully ported stock castings and the voodoo cam.
              • The cost of splaying the main caps and getting billet caps is not needed for your goals. A 2 bolt main will easily hold.
                Also basically you just relash every oil change. So when you change the oil, pull the covers and do the lashing.
                Originally posted by Yoshi94
                • Got a couple parts in this week.
                  And the machine shop sent me a few pics.
                  The new pistons
                  The block all ready to be line bored with the new splayed caps
                  And the Heads all cleaned up and ready for porting
                  • Please tell me you did not buy the Ram Gap intake manifold?
                    • I didn't know people still bought Edlebrock intakes. Looks like some fun goodies!
                      • Originally posted by Fox Slaughter View Post
                        I sure did!! lol
                        Hey! lol And I know i wish i had more photos of the important parts like the crank, rods, cam, etc but my machine shop guy took charge of all of that.
                          This!! Stud the 2-bolt! Splayed caps are not necessary and some people even swear they make blocks weaker since that area of the block is not meant to be load bearing. Also watch for the cheap chinese caps.
                          Also make sure oiling is upgraded at least with the GM white spring
                            I honesty don't know what he ended up getting for caps but mine are junk. And he said he is ordering a high pressure pump not a high volume. I'm really just going off what he has been telling me. I wish i would have had everything set up to just take to him. I just want it to be strong and stay together for a long time!
                            • 2002 Z28 Camaro A4
                              1993 Z28 Camaro M6- SOLD
                              1999 Z28 Camaro M6- SOLD
                              2008 Ford Fusion SE - DD
                              • Originally posted by Purple94Z28 View Post
                                He is correct in using a high pressure pump over high volume. Whatever it ends up being i wouldnt sweat it too much, sounds like he knows his stuff.
