  • #61
    that seems like a pretty good number!
    Yes sir! I am pretty excited to see what she weighs in at when im done with the weight reduction.
    2002 Z28 Camaro A4
    • #62
      wow my car is a huge fatty, nice weight to start
      • #63
        Yeah, mine is 3420 w/o driver. Thats pretty light. 60lbs lighter that normal. Congrats. I know i lost a bunch of weight losing the factory manifolds, cats, and exhaust. Eric L
        • #64
          Well, got lots done in the past couple days, my buddy helped a ton, so we got the interior ripped apart pretty quick.
          Center counsel out
          Pretty nasty!
          Next was the seat belts and the back seats
          2 minutes later.....Carpet is out
          Found some random bolts and also some rust.
          What is this? It is mounted behind drivers rear seat.
          Stuff is starting to pile up!
          Took the rear seat brackets out
          Rear seat brackets
          Also took out the rear seatbelts, and i will be taking out the rear seat belt brackets and also the brackets where the rear seats bolt into. It isn't going to be much weight but it will make the carpet fit much better when i put it back in. I plan on pretreating the carpet and scrubbing it, then powerwashing it. Then extracting the water out. This should make it look pretty new! (i detail, this is what we do for floor mats).
          I think Im going to go get it weighed again tonight. Just for shits and giggles, I plan on putting the carpet back in and also the plastics.
          Can i cut off the bracket for the spare tire? Or drill out the resistant welds?
          2002 Z28 Camaro A4
          • #65
            dang, your wasting no time at all!
            looks good. going to keep the automatic?
            • #66
              A manual valve body TH350 would be light, so would a 10" 4200 converter, lol, mmmmm tasty. Eric L
              • #67
                Looking good! keep it up
                • #68
                  The part mounted to the rear seat area is the plug for the rear end and I think the fuel pump.
                  • #69
                    Cool.
                    Thanks guys.
                    2002 Z28 Camaro A4
                    • #70
                      GOOD LUCK MAN! nice to see that the camaro will be brought back from the dead! man what did that kid do to that car its sad
                      • #71
                        thanks
                        2002 Z28 Camaro A4
                        • #72
                          Anyone know anything about cages?
                          http://www.summitracing.com/parts/CEE-3131/?image=large
                          2002 Z28 Camaro A4
                          • #73
                            Originally posted by mcalus View Post
                            Thanks everyone!
                            Yes, lots of work to do, but I have plenty of time to do it.
                            After I fix the body, I have 2 choices...
                            A) Take it to the track and see how good of a E.T I can get with it being close to stock, previous owner got best of 14.1. with 2.1 60's. But I want MY own time slip.
                            B) Rip the engine out. Cam/ Maybe heads/ Intake, LT's, Dumped TD's, Electric water pump, plugs, Trans work (costly?), suspension. Leave the rear until i goes.
                            Suggestions?
                            Here is a list of parts I am going to need. Now just because im listing it, doesn't mean if you have it ill jump on it. These are some parts I am going to get overtime. I am still a broke college kid
                            STOCK hood (doesn't matter color)
                            Plastic headlight holder
                            Smooth elbow for intake (prefer metal aftermarket one)
                            Stock corners (ill trade my clears straight up)
                            Passenger side seat belt thingy (keeps the seatbelt out of you face, screws into the seat)
                            LT's (the cheaper the better)(supporting stuff, o2 extentions etc)
                            Any suspension parts (aftermarket)
                            Trans build kit? (dont know anything about this)
                            Down the road (cam prolly the GM847, Stall ~2500ish, LT4 worth it?, supporting cam mods (1.6rr's, gaskets, hardend pushrods etc)
                            TD's dumped (cheaper the better)
                            Electric water pump
                            A/C delete belt
                            UDP (worth it?)
                            Pillar guages w/ 2 guage pod
                            CAI
                            Slicks
                            Light gray headliner (no ttops)
                            I am trying to keep the outside as sleeper as possible, I have my 99 LS1 for the looks (i know its backwards, but the 99 is in MUCH better shape)
                            I plan on getting the car weighed before I do any weight reduction and then getting it weighed after.
                            The A/C will be deleted, inner fender skirts will have quite a bit cut away, probably leave interior stock.
                            Questions:
                            Will my Pro kit fit on the LT1? If so I will most likly put that on there and get strano or something for the LS1.
                            I want to take the center counsel apaprt to see how much crap is under it, I am going to extract the carpets. Anythign to worry about? How do I get the shift handel/button off?
                            Any sugestions??
                            Idk if this helps but im getting a new hood for mine maybe ss idk yet tho but if you havent got a new hood by then mine will be up for sale it just has a few stone chips and rash from a bra that came on the car. Just thought I would let you know.
                            --Double post auto merged--
                            Are you wanting to take the e-brake off entirely or you're trying to remove the center console? The e-brake system is pretty straight forward - especially for calipers - so I doubt it'd get frozen if you pulled the e-brake up.
                            when i pulled mine all the way up when i took my console out it snapped under the car where the two cables meet .
                            Last edited by white97z28; October 14th, 2009, 06:10 PM. Reason: Auto merged double post
                            • #74
                              I ended up getting the center counsel out successfully, I have another member lined up to get a hood. Thanks for the offer though. Unless your selling it crazy cheap
                              2002 Z28 Camaro A4
                              • #75
                                lol we'll see
