my guess is no, the teeth are not any thicker.
Originally posted by DETROITMUSCLE View Postmy guess is no, the teeth are not any thicker.Why are you two in an LT1 thread? Isn't this topic a little too slow/non race car for you both?Originally posted by c0ncEpT View PostI agree. The teeth aren't thicker but the ring gear flange itself is thicker.2015 Silverado
Let me know mike! ThanksOriginally posted by my1994z28 View PostMike,I am going to be changing from 3.73s to 4.10s in the next 2 weeks...Let me know if you are still looking for 3.73s..My gears are GM gears..
2002 Z28 Camaro A4
A little update.
Got some new meats for the fronts, which was much needed if any of you saw the tires I had on it at the m&g
In getting a weird miss or lost of fuel pressure up top. What's strange is it's only over ~40-50 mph, it's like I'm on and off the gas when really the peddel is to the floor.
Also, idk if it's cam surge or what but between 40-50 mph it the rpms kick up then go back down, even when I'm just cruising.
I'm still running a lt1 km and sensor. Also I haven't gotten the heated O2 sensor conversion. I'm unsure if that will effect it.
I really want to figure out this high rpm issue and also get some gears still and see how it drives then.
Edit:
Also let my girlfriend drive it home from town one night. She was stoked!
Would I benefit from 42lb injectors? I have no clue what duty cycle mine are running at. Currently I'm running stock (22lb) ones right now.
Maybe I should focus on gears?
I ordered a few suspension goodies from founders, wish I could have bought more but next weeks vacation is going to take a good chunk of cash from the bank roll
is that a pic of your car now?? it looks BADASS!!!! you should be exstatic to have that nice of a car again ,IMHO looks 100 times better than the 9999 Buick Regal GS- New DD
SOLD-1967 Buick Skylark
42lb injectors seems way over kill. I only have 30lb injectors in mine.Originally posted by mcalus View PostWould I benefit from 42lb injectors? I have no clue what duty cycle mine are running at. Currently I'm running stock (22lb) ones right now.
The reason I ask 42 is because a member is selling some for cheap, I really font want to drop $300+ on a brand new set. Plus I'll need a retune before I start it also.Originally posted by meissen View Post42lb injectors seems way over kill. I only have 30lb injectors in mine.2002 Z28 Camaro A4
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
I was in the same position with the injectors on my last engine and I bought the 42's. Were they way overkill? Yes. Did they work? Yes.
If Jim was able to run 42lb'ers OK then go for it. I was worried about the duty cycle being too low, as I thought having too big of an injector is a bad thing. But if it worked for Jim, go for it!- Brian Meissen
What was your setup?Originally posted by birdie2000 View PostI was in the same position with the injectors on my last engine and I bought the 42's. Were they way overkill? Yes. Did they work? Yes.2002 Z28 Camaro A4
