1970 Chevelle Restoration
    Very cool. Your phone broken?
    thanks, I don't think so its flip phone is pretty durable
    • Originally posted by bri2203 View Post
      Hint hint meaning you should probably call when your tinkering around with this, well you used too! Nice job tho I know how much you wanted those to work. Glad to see that they do!
        You have your own project that keeps you busy among other thing that are going on in your life plus my plans are never concrete, it just worked out today that I was able to be productive. Up next is mounting and wiring the washer fluid contianer.
        • call me sometime. I haven't touched my car in a week and have nothing else going on. Just offering a helping hand no big deal if you dont want it!
          Keep it up, hopefully see this on the road come spring
            Thanks for the offer, I will keep it in mind. My list contniues to grow as I check things off. I am considering changing the transmission and maybe adding headers this winter.
            • I had a 1971 Monte Carlo SS 454 with the Lamp Monitor option. Very rare option. Does you Chevelle have the low washer fluid monitor?
              • Originally posted by 2002Z4CSS View Post
                Yes it does option code CD2. That is the next item on my checklist to get working properly. The factory actually used scotch locks!, for to light up the washer fluid light bulb. I will be redesigning that.
                  Below are the pictures of it
                  I am very please I was able to get this option working.
                  Up next is routing the washer hoses then I will find out if my my electro tip wipers work properly. That option is very rare 331 units produced.
                  • what other cool options did chevelles have that you dont even find on vehicles anymore?
                    00 Tahoe Z71........Stock
                      IMO the coolest option the chevelle has was the fuctional cowl induction hood. Meaning the hood had door at the high pressure area in front of the windshield and it would open and feed fresh air to the carburetor when it was floored.
                      • i remember that my moms ex bf had that option, he let me drive it and i got too distracted by how cool that was, so he told me to rev it up in the driveway. boy was it awesome to hear that 396 roar and feel the ground just shake. he later sold it on barret jackson i believe or something similar
                          reminds me of my 83 camaro Z28 with the fuctional ram air when floored (had the cross-fire fuel injection system)
                            Was that vacuum driven? Seems like I see a lot of Chevelles running around with that either stuck open or closed. Or was there a manual control on it too?
                            • depends ifit was facotry or not, lots of people ive noticed throw on the original hoods and hack up the functionality of it, others buy aftermarkets that are just open, but the original option were all vaccuum i do believe
                                Yes it is vacuum cocntroled. The ones that you see are either broken or they fixed to stay open all the time. Some people even reverse the door so it was more of a scoop because they are not aware of the high pressure area at the windshield
