View Post
1970 Chevelle Restoration
Hint hint meaning you should probably call when your tinkering around with this, well you used too! Nice job tho I know how much you wanted those to work. Glad to see that they do!Originally posted by bri2203 View Postthanks, I don't think so its flip phone is pretty durablesigpic
You have your own project that keeps you busy among other thing that are going on in your life plus my plans are never concrete, it just worked out today that I was able to be productive. Up next is mounting and wiring the washer fluid contianer.Originally posted by Darren View PostHint hint meaning you should probably call when your tinkering around with this, well you used too! Nice job tho I know how much you wanted those to work. Glad to see that they do!Last edited by bri2203; December 4th, 2011, 12:48 AM.
call me sometime. I haven't touched my car in a week and have nothing else going on. Just offering a helping hand no big deal if you dont want it!
Keep it up, hopefully see this on the road come springsigpic
Thanks for the offer, I will keep it in mind. My list contniues to grow as I check things off. I am considering changing the transmission and maybe adding headers this winter.Originally posted by Darren View Post
Yes it does option code CD2. That is the next item on my checklist to get working properly. The factory actually used scotch locks!, for to light up the washer fluid light bulb. I will be redesigning that.Originally posted by 2002Z4CSS View PostI had a 1971 Monte Carlo SS 454 with the Lamp Monitor option. Very rare option. Does you Chevelle have the low washer fluid monitor?
Below are the pictures of itOriginally posted by 2002Z4CSS View PostI had a 1971 Monte Carlo SS 454 with the Lamp Monitor option. Very rare option. Does you Chevelle have the low washer fluid monitor?
I am very please I was able to get this option working.
Up next is routing the washer hoses then I will find out if my my electro tip wipers work properly. That option is very rare 331 units produced.
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
what other cool options did chevelles have that you dont even find on vehicles anymore?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
IMO the coolest option the chevelle has was the fuctional cowl induction hood. Meaning the hood had door at the high pressure area in front of the windshield and it would open and feed fresh air to the carburetor when it was floored.Originally posted by TylerT/AZ28 View Postwhat other cool options did chevelles have that you dont even find on vehicles anymore?
Post Whore
- 3000
- Tyler Porter
- student
i remember that my moms ex bf had that option, he let me drive it and i got too distracted by how cool that was, so he told me to rev it up in the driveway. boy was it awesome to hear that 396 roar and feel the ground just shake. he later sold it on barret jackson i believe or something similar91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
reminds me of my 83 camaro Z28 with the fuctional ram air when floored (had the cross-fire fuel injection system)Originally posted by bri2203 View PostIMO the coolest option the chevelle has was the fuctional cowl induction hood. Meaning the hood had door at the high pressure area in front of the windshield and it would open and feed fresh air to the carburetor when it was floored.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Was that vacuum driven? Seems like I see a lot of Chevelles running around with that either stuck open or closed. Or was there a manual control on it too?Originally posted by bri2203 View PostIMO the coolest option the chevelle has was the fuctional cowl induction hood. Meaning the hood had door at the high pressure area in front of the windshield and it would open and feed fresh air to the carburetor when it was floored.-Joel
Post Whore
- 3000
- Tyler Porter
- student
depends ifit was facotry or not, lots of people ive noticed throw on the original hoods and hack up the functionality of it, others buy aftermarkets that are just open, but the original option were all vaccuum i do believe91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Yes it is vacuum cocntroled. The ones that you see are either broken or they fixed to stay open all the time. Some people even reverse the door so it was more of a scoop because they are not aware of the high pressure area at the windshieldOriginally posted by JoeliusZ28 View PostWas that vacuum driven? Seems like I see a lot of Chevelles running around with that either stuck open or closed. Or was there a manual control on it too?
