Very nice, I would love a Chevelle someday, and a 55', a vette....
1970 Chevelle Restoration
I had my original carburetor remanufactured. I am very pleased with how it looks. I installed it tonight but it still needs to fine tuned as I am not happy how it idles. I should have a video by this weekend.
carb 001.JPGLast edited by bri2203; September 22nd, 2011, 08:33 PM.
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
are you still running those stock manifolds?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Originally posted by OVRKILL View Postlovin it B.....tweak those exhaust pipes and dial in that wheel combo....
lmao...my "unsolicited opinion"
Thanks Brent!
The exhaust bothers me as well but it sounds good. The previous owner paid $240.01 for this exhaust in 1998!
It will likely be replaced in the future I just couldn't justify trashing a decent exhaust to spend close to a grand on a system I would be happy with.
Care to elaborate more on the wheel combo?
Yeap! When I replace the exhaust I will consider headers but there is a good chance I will keep the manifolds.Originally posted by TylerT/AZ28 View Postare you still running those stock manifolds?
Thanks, for the suggestion. The car wants to stall when you cover the air horn so it not a vacuum leak. I hope to look at it closer tomorrow.Originally posted by 2002Z4CSS View PostCarb looks good. Put your hand over the top of the air horn while it is idling and see if the RPMs go higher or the engine stalls. Higher RPMs would indicate a vacuum leak somewhere.
Post Whore
- 3000
- Tyler Porter
- student
if you want headers i have a set of longtubes in the garage, from a 70 chevelee that were taken off because my friend swapped a 396 in it. if you would like them, make me an offer91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Turns out I did have a vacuum leak. The rubber hose at the tranmission modual broke.Originally posted by 2002Z4CSS View PostCarb looks good. Put your hand over the top of the air horn while it is idling and see if the RPMs go higher or the engine stalls. Higher RPMs would indicate a vacuum leak somewhere.
Post Whore
- 3000
- Tyler Porter
- student
did you ever get my pm's?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
I am pretty impressed with what I accomplished today. My chevelle had a few rare options one being fiber optics lamp monitors. A fiber optic cable would reflect light to an ordiment on the fenders or on the package tray so you could tell if your lights/brake lights/ turn signals/brights were on. The previous owner cut these cables and normally you can't just splice them together. The good news is I am very happy with how well I got my rear fiber optics working.
The bulb on the left is the right tail light, the middle is the licence plate light and one on the right is the left tail light. ill be making some more progress tomorrow.
Very cool. Your phone broken?sigpic
Post Whore
- 3000
- Tyler Porter
- student
thats awesome never seen that before91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Very cool can't wait to come see itThe Original
